749 sense resistors change
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi..
Going to change my 749 to handle 8 p/h injectors now, I have the drivers and some 0.05 1% 2W resistors, but after reading about Funsticks conversion and he used 0.05 1% 5W. I guess that both options work but what would be best to use?
/N.
/N.
Re: 749 sense resistors change
Originally posted by gta324
Hi..
/N.
Hi..
/N.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Originally posted by BMmonteSS
Where might one find this article?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: Re: 749 sense resistors change
Originally posted by funstick
as long as the impedence is the same using a higher wattage resistor shouldnt cuase any trouble. you can use pretty much any wattage the issue is going to be in fitting in on the board.
/N.
Re: Re: Re: 749 sense resistors change
So I wont risk to burn the resistors if I use 2watts?
/N.
/N.
