Quick WOT AFR question...
Old Oct 18, 2004 | 10:00 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
in the %Change A/F vs RPM @ WOT tables (MAF here) will I want a negative value (14.7 - 1.2 = 13.5 afr) or a positive value to richen up the mixture?
Old Oct 19, 2004 | 12:40 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
https://www.thirdgen.org/techbb2/sho...hreadid=259424
Check this out. To get to the air fuel ratio you want, say 12.5:1, take where you are divided by where you want to go x100% -100%, i.e. 14.7/12.5*100%-100%=17.6% ADDED. The ECU calculates it this way (less directly, but it does, see the link, I did the math there using the ECU's equation).
There are a few ways to add fuel in Power Enrichment, 1st being PE %Fuel adder vs Temp, and also vs RPM. As long as your hack is reporting the percents correctly, you can just add them together to get the total PE (again, see the link, I had to fixe the $6E to be correct).
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
ULTM8Z
Oct 2, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Damon
Sep 26, 2015 04:29 PM
