$8D Set Up help?
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
$8D Set Up help?
Ok due to a bad maf sensor I have decided to switch over to SD rather than replace it. So I am going through the S-AUJP bin and setting it up for my needs. I have a absoultley Stock 1985 LB9 (Untill next year)Well My question is how do I figure Cylinder Volume Constant for my 5.0l 305 LB9, and I already set the injector constant to 19lbs, is there anything else that would have to be changed to work on my combo. Thanks sorry for the ignorance, I am just starting to rearsearch the 730 $8d stuff and yes I used the search function.
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
I'm running S_AUJP_CCP with my '87 LB9 and the way I figured it was: 5.0 liters=5000cc/8 cylinders=625cc per cyl.
Car: check
Engine: check
Transmission: check
For cylinder volume constant:
CAL = L/CYL * 223.157
(5.0 / 8) *223.157 = x
May be worthwhile to start with or at least look at a stock 5.0 TPI $8D bin. Could also copy tables and such over from a 5.0 TPI bin.
RBob.
RBob.
Car: 1987 Z28
I use TunerPro and it asks for cylinder volume in cc/cyl, maybe I should've mentioned that. Don't know what you're using to edit your bins with, others may be different..............
online converter
online converter
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Cool Thanks, and Yes I am using Tuner Pro Well I noticed that in AXXF the Cylinder Volume Constant is set to 623.32
Well RBob thanks I really should of thaught about looking at a 5.0 Bin but it sliped my mind. See what happens when you work 3rd shift and wake up at 4:00pm everyday.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
[Sold] Accel 30# injectors
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
