S_aujp_ccp
Car: 1992 Z28
S_aujp_ccp
I'm a newbie to Prom burning and have learned so much from his board. I'm still a bit lost but I was warned from the stickies..."patience"
Well, after getting all the hardware needed, I burned my first chip and it was the S_AUJP_CCP. Had fun with the memcal and finally cranked the car up. WOW! This baseline bin really woke my car up. The only thing I changed, was the fuel injector constant to match my 24lbs.
I forgot I installed a 180 thermo so I'll probably go back and change the fan on/off settings.
The car runs great and no codes.
I really wanted to thank all who kept this post alive and also to TRAXION for starting it...you should start a book.
Now I need to learn about VE tables and how to smooth things out.
