It will let me view any logs about 1500 frames or less, but anything over that will display as 1/0 frames. I cannot export them to comma delimiting format, and I cannot view the sensor data on playback. If I press play, it will show the bit data accurately (I have a MAT error that it shows), it will show the switching sample rate, and about 10 minutes of playback it will show the 1 error count that the log has. But like I said, it doesn't display the sample count accurately, it won't let me view sensor data, and it won't let me export to .csv. The files in question are all roughly 10,000-15,000 hz, or 15-20 minutes at 10hz.
I have tried this on my laptop that I log with, and I have tried it on my desktop which is quite a bit faster. Neither will work.
Am I stuck logging smaller files? Any one else have this issue? Datamaster seems to work ok for me, but I'd like to register whatever program I decide on. And with datamaster at $120 and this one at $30, I'd rather go with tunerpro. Not to mention the fact that tunerpro is a better program anyways
Thanks for any help guys
Might want to toss Mangus an email. I know he's been working on the ALDL stuff quite a bit lately...
Can you zip and send me the log along with the ADS file you're using?
mmansur at hotmail
mmansur at hotmail
I just sent it out. I included a second log file as well with nine sessions, the majority of them I can't view either.
Thanks for the help Mark, I really appreciate it.
The laptop is a PII 300 mhz compaq armada with 128mb ram, running XP home edition.
The desktop is celeron 2.0ghz dell with 640mb ram, also running XP home.
I can dig up any other stats if you need them
