Conversion factor for AE PW to usecs?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Im doing up another TC definition file and the value I got for conversion factor for converting the raw accel enrich pulsewidth counts in the accel enrich tables to actual time is (table value x 256) x 15.26 µsecs, which is 3.9 msecs of 'pump shot' for each count of pulsewidth that is stored in the table.
Looks like the values looked up from the tables are stored as the MSB of the temperary async. fuel accumulator and there are 15.26 µsecs per count. Problem is the other multipliers floating around for converting the AE PW in the TPS and MAP AE tables to actual time are something like 60.1 µsecs per count. Is there something Im missing? Or are these previous conversion factors wrong?
EDIT: This is relating to the TBI ecms.
Car: 88 Camaro SC
Engine: SFI'd 350
I tested it out on the bench. Theres around one second of accel enrich when one of the tables is maxed out with 255 so it looks like its 3.9 msec per count of AE in the table.
2012sergen11
Oct 13, 2015 07:38 PM
