$58/$60 timing map question (did search)
Old Dec 7, 2004 | 12:38 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
I'm sorry if this is painfully obvious, but I have looked through the "timing section" of the source code on $60 and through the maps in TunerCat. I have also searched here.
I can basically see that fuel/VE under boost and at higher RPM is handled with a multiplier. How is timing handled above 4800RPM? The main spark advance map seems to stop there, and I can see the boost spark advance correction vs. MAT vs. Boost table takes some timing out at higher KPA's.. but what is that being subtracted from? Etc.
Is there something I'm missing here?
Thanks!
Old Dec 7, 2004 | 07:53 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: $58/$60 timing map question (did search)
It slopes in additonal timing.
Starting at RPMXHI, it will add ADVSLHI in degrees per 1,000 rpm.
RPMXHI: FCB 255 ;F1 Table Extension Hi RPM Breakpoint
ADVSLHI: FCB 0 ;Hi RPM Advance Slope
Obviously, it's disabled in the settings shown.
Old Dec 7, 2004 | 08:40 AM
Axle/Gears: 3.73:1
Ok. So, for instance, if that feature is disabled and the main spark map is set for 15° at 170kpa and 4800rpm... does that also mean that it will give 15° at 170kpa at 6000rpm, for example?
And if that is true, if at 70kpa boost the "Boost spark advance correction vs. MAT vs. Boost" map shows -5° for example.. can I expect 10° of timing at that boost level? (Of course, if I set it to slope in timing above 4800RPM, this would no longer be true.)
And finally, are these numbers taking base timing into account, or are they in addition to base timing? I assume that they are including base timing, but I just wanted to check.
Thanks again.
Old Dec 7, 2004 | 09:02 AM
Axle/Gears: 3.73:1
Also, is there a reason that, when I look at the bin file I have from the $60 source code in Tunercat, the "spark reference angle" is set to 70°, and the "maximum spark retard relative to reference" is -74.88°?
In the code I see:
MAXADV2: FCB 0, 85 ;Max Advance Relative to Reference
and
MAXRTD2: FCB 255, 43 ;Max Retard Relative to Reference
Does that "0" after "FCB" mean that the max advance relative to reference is not enabled? And does the "43" after "FCB 255" on max retard mean that 43° is the actual max amount? Or do those numbers have nothing to do with what I'm talking about...
Just want to make sure I'm not making any mistakes.
Old Dec 7, 2004 | 11:32 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
In the code I see:
MAXADV2: FCB 0, 85 ;Max Advance Relative to Reference and
You need to reread the opening statements.
Before running the 60 code, you need to verify that it matches what it is you've run. ie, in every entry, and use the entries that you have been using.
At this stage, I'd suggest you stick with the stock 58 code until you get more familiar with what you're doing. Not meaning to *slam* you, just that it seems you've missed the point of the opening statements.
Old Dec 8, 2004 | 01:20 AM
Axle/Gears: 3.73:1
No offense taken. I'll look over it again and again until it makes sense. I don't see any reason why I can't make the stock 58 code work for me, my main concern at this point was to get an idea how timing was affected after the end of the main spark map.
Caspar
Jun 19, 2016 11:19 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
