prom installation without g1 adapter
Subscribe
Dec 15, 2004 | 05:40 PM
i know everyone recommends the moates g1 adapter for installing new proms. i got one of these and i dont understand how it works. i read the directions very carefully on the moates website and i dont get it. the previous owner installed a hypertech chip so maybe my setup is a little different. anyway, since i couldnt figure it out, i just removed the old prom and put the new prom in without using the adapter. common sense seems to tell me that this should work fine, but i just want to make sure because it seems like evvveryone uses the g1 adapter. so am i okay? thanks guys
Reply 0
Dec 15, 2004 | 06:35 PM
Hypertech used several different set ups, so without knowing which one, it's kind of hard to tell what you have.
Can you post a pic of what pieces you do have?.
If you have an ecm with 3 connectors, on it, (I can't get to Moates site to couble check if the G1 is for the 2 or 3 connector ecm).
If you do have the stock *memcal* ie the piece with the blue cover then that should plug directly into the ecm socket.
Reply 0
Dec 15, 2004 | 07:42 PM
sorry no camera no pics
the hypertech chip has the prom and then two little things mounted on a black surface that plugs into the blue socket. there is a white cover that mounts over the black part. i just took out the prom in the hypertech chip and put my prom in there. sorry if that doesnt make it any clearer.
Reply 0
Dec 15, 2004 | 07:49 PM
Sounds like the "modified memcal" version of the HyperJunk. Basically they took the stock eprom out of the memcal and put a socket in it's place, then put their chip in the socket.
What you did should work just fine.
Reply 0
Dec 15, 2004 | 07:51 PM
awesome thanks
Reply 0
Subscribe
