While we're at it...
Old Dec 25, 2004 | 07:17 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
'84-'85 GN Maf = Cardone #74-7699
'86-'87 GN Maf = Cardone #74-7899
Any ideas on the differences?
Old Dec 25, 2004 | 07:58 PM
funstick's Avatar
Re: While we're at it...
yes 84-85 is a hot wire Bosch tpi design i do belive and the 86-87 peice is a film style AC delco peice. it could be the other way around.
Old Dec 25, 2004 | 11:31 PM
Doward's Avatar
My sources are quoted as having said -
'The hot-film MAFs, which AC Rochester
introduced in 1984 on the Buick turbo 3.8L
V6 and were also used on Chevrolet 2.8L
engines and GM 3.0L and 3.8L V6 engines,
produce a square-wave variable frequency
output. The frequency range varies from 32
to 150 Hz, with 32 Hz being average for idle
and 150 Hz for wide-open throttle'
This from a Wells Counterpoint issue.
Perhaps the '84-'85 are the hot film frequency based MAFs, similar to the 2.8's?
Old Dec 26, 2004 | 07:40 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I believe you are correct in the frequency output of the earlier ones. Cant verify the use of them on toher cars however.
I dont know alot about the earlier ones, but the later 86-89 MAF was pretty much junk if u got a good one , u did, the rest would just crap out in a week it seems. Something like a MAF translator(if u can make it work) may work really nice for you if u can use it. Let u run a late model MAF and they are alot cheaper and way more reliable.
later
Jeremy
Old Dec 26, 2004 | 06:06 PM
Doward's Avatar
Hmm... I think I'll pick up like an '84 GN Maf, see about using it in place of the stock 2.8 one
okfoz
Oct 13, 2015 02:19 PM
85cmroz28
Oct 4, 2015 09:44 PM
luvofjah
Sep 26, 2015 08:28 PM
CORV3TT3
Aug 23, 2015 11:26 AM
CD MaroMan 91
Nov 28, 2001 04:45 AM
