WinALDL one data log only!
Old Dec 27, 2004 | 06:23 PM
aroc's Avatar
Built the cable to connect computer to car (92 camaro 305 TBI) as per schematic on Win ALDL site. Attached cable to car and computer, started computer, started car and launched Win ALDL program. One column of data appeared on raw data screen. Also only one column of data on interpreted data screen. Checked com port for correct one and correct speed. Tried the 10K resistor between pins A and B on ALDL connector same results. Values were posted for everthing except RPM amd MPH. Car was in park idleing so 0 mph is expected. Shut the car off but left it in the on position. Several more columns of data posted. Why is data no logging while engine is running? I am out of ideas.
Old Dec 31, 2004 | 09:50 AM
aroc's Avatar
Problem Solved
A reexamination of the cable revealed transistor was installed backwards. Transistor reveresed. Everything working now!
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
