my chip problems
Old Jan 3, 2005 | 05:25 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
my chip problems
Having problems with prgramming. using BURN1 programmer, 27sf512
> chips,
ecm is 1228746. 91 tbi camaro.
> need to load 4k bin on one of these chips. tried putting the bins at the start, offsetted, and stacked to the full 64k. It still is not running right. What's odd is that no Prom error is coming up. Another stock ECM with stock chip works in it yet this does not work and it sounds like a massive vacuum leak that doesn't appear with a stock ECM in there. Should I be offsetting the 4k bin or what? Could you help try to let me know what could possibly be wrong with this.
programming the chip from F000-FFFF is what we did as well.
Old Jan 3, 2005 | 06:06 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Thats funny, thats the correct offset to use. What kind of adapter are you using to use the 28 pin chip. I'm using one of craigs adapters, but there are ways to make your own. Also make sure you are calculating the checksum. Not all editors do this automatically. Other than that, it could be loose/bad connection on one of the pins. Did you put in a regular socket or are you using the stock one?
Old Jan 4, 2005 | 07:13 AM
bbtaz97's Avatar
Car: 91 RS
im using the g2 adaptor form moates... im gonna check the connections later but we werrnt gettign the rapid flashing service engine soon light. i also will post a pic later of what we are using.
Street Lethal
Apr 30, 2019 12:14 PM
inferno15
Aug 29, 2015 01:48 AM
ambainb
Aug 29, 2015 12:43 AM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
