Data logging
Old Jan 13, 2005 | 08:14 PM
91 z28 350's Avatar
Car: 91 Z28
Data logging
I'm having problems data logging using tunerpro rt and the auto prom. i got it to connect using com 3 but it doesn't produce any data. After that i changed the interface to auto prom and it won't connect. What am i doin wrong ? Also what is the packet error count ??? I have the horizontal switch away from the usb connector and i have the vertical switch all the way up.
Old Jan 13, 2005 | 11:39 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If the horizontal switch is away from the USB port, you'll want to set TunerPro RT to use the "MAX232" interface type.
I don't believe you need the 10k for your '91, so you can place the vertical switch in the middle position.
You'll need to load the 1227730.ads file.
Additionally, you'll need to confirm which port the AutoProm is utilizing (COM3 or COM4 usually). You can confirm by looking in the device manager (for notes, look here:
http://www.moates.net/documentation....7f9f83ee102283
After that's all set up, click the "connect to ECM" button until it connects (for the 7730, it shoud connect on the first or second try).
M
Old Jan 15, 2005 | 10:51 PM
91 z28 350's Avatar
Car: 91 Z28
I got i t to work and then all of a sudden when i try to do it again it stops working. I dunno i borrowrd a friends laptop and it has alot of problems so it my just be the computer it self.
Old Feb 3, 2005 | 05:38 PM
91 z28 350's Avatar
Car: 91 Z28
Another problme i foun i can't record my data log i keep getting an error
Old Feb 3, 2005 | 05:39 PM
Mangus's Avatar
Transmission: T5WC
Did you select the file to record to before hitting record?
Old Feb 5, 2005 | 11:54 PM
91 z28 350's Avatar
Car: 91 Z28
ok i think i figured it out
Falcon50
Aug 22, 2020 03:26 PM
L98GTA87
Oct 19, 2015 10:43 PM
bjpotter
Oct 4, 2015 07:48 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
