Calling Zeitronix WB owners
I bought a ZT-2 in the group buy here a few months ago and it has been working flawlessly until today.
I went for a drive this morning, all was going well until the display went to full scale (21) a few times, but it seems to be a permanent condition now.
If i disconnect the sensor while the laptop is logging, the reading goes from 21.0 to 14.5 instantly, and returns to 21 as soon as the sensor is reconnected.
I am guessing my sensor is dead, as everything else appears to be working.
Are there any tests I can do with a multimeter to confirm the sensor is dead?
I am surprised by its short lifespan. I never use fuel additives, and I have never run the motor with the sensor not powered up.
Any thoughts?
Who's the best supplier of the LSU sensor these days?
Any thoughts?
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Your sensor shouldn't be shot yet. The only thing I can think of is the placement of the O2. Zt says you should mount the sensor in the 10 to 2 o'clock postion to keep moisture from settling in the sensor. I guess it shortens the sensors life or completely messes with it.
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Also exhaust leaks will throw it off a lot... My o2's are after the collectors and sometimes the thing will read ridiculously high even when theirs no audible leaks.
On mine when their's a collector leak the WB will read ridicously high, but when you go WOT the readings will drop to about where they should be.
Hotrodboba400
Dec 10, 2019 07:07 PM
david068513
Sep 18, 2015 10:36 AM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
