Converting to SD ECM
I just got a 16198262 ECM. It says this on the ECM "Remanufactured by GM Corp. Service No. 16198262". Anyway I got this ECM so I can go to Speed Density.
Now, I've programmed using the old ARAP.bin file for 1227165, but I am new to SD. I've got Tunerpro, and was wondering what BIN file goes with their Super_8dm2.ecu definition. Or if anyone has a better suggestion for bin/ecu, I'm open to it.
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Try AUJP or Traxion's S_AUJP. I've been using the latter with good success on my SD conversion for some time now.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The AUJP is for an automatic 4 speed trans. If you have a manual its probly not the best to start with. If you do have auto, it's an excellent starting point although some have seen there is too much timing for thier combo and backed it off a bit. Ran it on my L98 w/ iron 1.94 heads and it ran very well. Good luck.
