Are there any common mistakes when building a max232 cable?
Old Feb 11, 2005 | 06:05 AM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
I don't know. I've built seven cables. I would rate my soldering ability & understanding of schematics average. I use all the right parts. I heat sink when soldering sensitive electronics. Not one of my cables will pass tts's cable check program, or even link to the car. This has been verified on three computers. My 2 transistor will work. I have finally given up on the DIY cable idea & ordered parts from a cable manufacturer. Problem is; I spent more than twice what I would have in the first place. And burned my fingers a thousand times for nothing. Just wondering is there a common mistake that is often made?
Old Feb 11, 2005 | 10:46 AM
AlexJH's Avatar
Engine: 5.7L V8
Do you have bypass capacitors from the power to ground pins? As close as you can get to the two pins?
Old Feb 11, 2005 | 10:47 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hey there. I can't answer your question, but can you point me to the cable check program you are using? Will it check a 2 transistor cable? Thanks!
Old Feb 11, 2005 | 06:38 PM
87tpi7749's Avatar
Engine: 5.7L
I guess? I never really paid much attention to "how close" they were to pins. Most of the ones I've done are within an inch. Does this make a difference?
Old Feb 11, 2005 | 06:40 PM
87tpi7749's Avatar
Engine: 5.7L
The program is from tts power systems website, click down loads then aldl test, it should be easy to find. It is only for max232 cables, so no on the 2 transistor.
Old Feb 12, 2005 | 02:09 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
It'll work on the 2-transistor cable as well.
Old Feb 12, 2005 | 08:30 AM
87tpi7749's Avatar
Engine: 5.7L
Craig, Is that true? My 2 transistor works flawlessly with freescan but fails every test I run with the aldl test program. All the max232 cables that fail the test also fail to cummunicate. It would seem I am running the test correctly (cable only) no coonection to ecm. Now I am really confused, but happy I bought a cable.
Old Feb 12, 2005 | 08:41 AM
stuckatcuse's Avatar
Car: Maybach
Engine: KA24DE-T
Transmission: M5
watch the polarity of the capacitors. Some of them are wired in reverse.
Old Feb 12, 2005 | 02:19 PM
87tpi7749's Avatar
Engine: 5.7L
I regard the (-) symbol on the side of the cap as negative. Is there a way to check poalrity with a meter?
Old Feb 12, 2005 | 06:26 PM
Car: 87 T/A
You're correct, - = negative. No, no way to tell. Hook em up backwards and give em enough juice and BAM! It's cool...
Old Feb 14, 2005 | 06:49 PM
AlexJH's Avatar
Engine: 5.7L V8
It can make a difference. When I put a circuit together, the bypass caps from +V to GND are as close as possible to the IC's pins.
How much electronics equipment do you have? Have you checked that the right voltages are on the power, ground pins?
Old Feb 14, 2005 | 08:17 PM
87tpi7749's Avatar
Engine: 5.7L
I got it working. With some help from a professional cable manufacturer, I discovered that my version of aldl test was the problem, I had to use the old version, all boards work! Thanks everyone for the tips, it makes DIY feel like you're not on your own, it should be more like DIWTGO (do it with thirdgen.org).
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
92firebirdguy
Sep 10, 2015 10:33 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
