AFR versus HP
Car: '89 IROC
Engine: TPI 383
AFR versus HP
Does anyone here have quantifiable data regarding the relationship between maximum power and air fuel ratio? For example, do all sbc engines make peak power at 12.8:1 or do some make peak power at 12:1 while others make peak power at 13.5:1? Do thermal and flow dynamics contribute to that (assumed) difference? Additional thoughts?
Car: An Ol Buick
Engine: Vsick
Re: AFR versus HP
While not SBC, I got to spend a couple days with an Innovative, and made a bunch of short passes, in some 10 sec GNs, and saw anything from low 10:1s, to high 11:1s. While I'm a firm believer in giving the engine what it wants, that solidifed the concept.
Car: '89 IROC
Engine: TPI 383
Grumpy, I remember a post you made quite some time ago regarding the coolant temperature relationship to power and, if I remember correctly, you believe a hot (200+*) engine makes more power than a warm (160*) engine. Do you have a temperature you are particularly fond of? Secondly, what AFR makes your engine most happy?
Car: An Ol Buick
Engine: Vsick
Depends on the type of tune, I'm running. While I generally favor a low timing style of tune, I've been also known to play with high timing. While 4-6d really isn't alot, at the higher boost levels it means running 10.8s compared to 11.8s. I've also run leaner AFRs at lower boost levels.
355tpipickup
Sep 28, 2015 05:50 PM
