IAC counts added in drive. Where are they from? 6E
Car: 2000 BMW M5
Hi guys, I am making great headway tuning my MAF tables and getting my cammed 327 to idle well and at the proper RPMS. One thing I can't get rid of are ~15 commanded IAC counts when the car is completely warmed up, in drive (the ALDL programs, both winaldl and Tunerpro, show that my manual park/drive toggle is working correctly). I zeroed out the "warm park IAC counts", and when I flip the toggle into park mode with the car warm, sure enough, I get zero counts and the car comes down to its target idle. As soon as I flip into drive mode, the car adds 15 IAC counts, which puts it around 150 rpms over target idle. I'd like to get rid of these in drive! I based my tune off a 1989 6E AYPY (corvette 6 sp manual) bin file. The only thing I can see that is slightly suspect is a "T/F" in gear IAC adder in the constants table (Tunerpro). What is T/F? (throttle follower?). I don't have a VSS, although I'm spending the 70 bucks to get the retrofit kit so I can run one with my Muncie 4 speed (I really want to be able to use the IAC as a throttle follower correctly, and have highway cruise mode active). Is this T/F IAC adder causing my problem at idle? The IAC jumps from 0 in park, hot, to 15 in drive, instantly when you toggle the switch, every time -- this isn't a random occurance.
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Out of curiosity, see what is at hex address 52B. If it's 15, try changing it to 0. If it's not 15, then it's not the right number.
Edit: Oops, I mean 0f. I just checked APYP (not AYPY) and that isn't the right number. There are a few 0F's in that general area though. Maybe experiment with changing them one at a time?
Car: check
Engine: check
Transmission: check
Re: IAC counts added in drive. Where are they from? 6E
RBob.
