Can someone explain Wideband 02 to me?
Old Mar 1, 2005 | 01:18 AM
NorcalZ71's Avatar
Car: 94 ECSB Midnight Blue Z71
Engine: 350 TBI
Transmission: 4l60e
As the title says, can anyone explain the WB02 to me? Seems this is the hot setup for tuning, but I dont quite get what it is or how it works?
Old Mar 1, 2005 | 01:28 AM
Z69's Avatar
Z69
Factory o2 sensor is only "accurate" at 14.7 to 1 AFR.
Completely unreliable at any other ratio.
Designed primarily for emissions control so the Cat works correctly.
A WB will read quite accurately from 10 or less out to 17 or something AFR repeatedly, reliably, and accurately.
So you can get a much finer tune for your particular engine.
Because you engine probably doesn't run it's best at 14.7.
Old Mar 1, 2005 | 01:35 AM
NorcalZ71's Avatar
Engine: 350 TBI
Transmission: 4l60e
ok, and what does one of these go for? Pricey from what I have gathered. Makes sense for the wider AFR range
Old Mar 1, 2005 | 08:20 AM
silvernblack's Avatar
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
Does it replace the regular O2 sensor?
And work with the 730 ECM?
OR is it used separately to monitor air/fuel ratio?
Old Mar 1, 2005 | 08:28 PM
brutalform's Avatar
You can pay more or less. You can also build your own from the instructions on some sites. Too much electronic work for me to try though. Check this out.
http://www.rx7store.net/browseproduc...deband-O2.html
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
efiguy
Sep 27, 2015 01:30 PM
tuningnewb
Sep 23, 2015 07:06 PM
