27SF512 problems...
Old Mar 29, 2005 | 01:44 AM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
27SF512 problems...
I can't seem to accomplish anything with my BURN1, Flash Burn, and my 27SF512 chip. I followed all the instructions in the readme file about the port settings, and I still get nothing. This is what I see when I start the program:
HW: v0.128.E
Reading device into buffer...
--------------------------------- (Here I try to read the chip)
ERROR: PROM I/O returned failure
The error changes slightly depending on what I try to do:
Erasing device...
ERROR: Erase Command returned failure
If I try to use Flash & Burn version 1.04 I get an error about hardware not being connected:
Supported Hardware not found!
Attach supported hardware and re-open application!
Anyone got any idea's?
Old Mar 29, 2005 | 02:43 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
You don't, by chance, have an ALDL cable plugged in between your car and your computer while trying to run the program, do you? If so, disconnet that first, then try.
The hardware version that is showing up in the log you pasted is wacky. You may have bad hardware.
Email Craig and he'll straighten the matter out.
Old Mar 29, 2005 | 05:24 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Looks that way to me. You didn't reflash it with the wrong firmware did you?
Old Mar 29, 2005 | 05:42 PM
Car: 87 T/A
Also may try closing the software programs, disconnecting the BURN1, and then reconnecting it after 10 seconds or so and restarting the software.
Old Apr 1, 2005 | 11:12 AM
neat's Avatar
Car: 1991 Corvette
I don't have anything plugged into the car when trying it. I am inside, at my desktop PC.
Old Apr 1, 2005 | 11:13 AM
neat's Avatar
Car: 1991 Corvette
I have never re-flashed it with any firmware.
Old Apr 1, 2005 | 11:14 AM
neat's Avatar
Car: 1991 Corvette
Have tried that, no luck.
S10Wildside
Jun 6, 2005 08:38 AM
scorp508
May 1, 2005 07:21 AM
NufNuffZ28
17
May 1, 2004 04:16 PM
novass
Jul 19, 2003 11:08 AM
