27SF512 Chip & Pocket Programmer 2
Old Apr 28, 2005 | 11:01 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Hi everyone,
I'm used to using the AT29C256 chips so the 27SF512 is new to me. Is it correct just to change the Device Start to 08000 and leave the device end at 0FFFF?
I'm burning a 32KB 1991 Y-Body Bin to it.
Thanks!
Old May 1, 2005 | 07:21 AM
clippjr8's Avatar
That is correct. After you burn it, set the device start back to 0000 and then use the ( M ) key to move the device to the buffer after it is moved you can hit the ( E ) key to edit the buffer. At the top you can type in 08000 and it will take you there to verify that the chip was programmed to the correct spot.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
86IROC112
Nov 7, 2015 06:50 AM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
