727 Wired as a 730
Old Apr 30, 2005 | 07:40 AM
engnerdan's Avatar
Car: 88 Mustang GT
Engine: 5.0
Transmission: TKO
727 Wired as a 730
I have searched and only found one link to a table showing how to wire a 727 up to run 730 code, but the table is not clear at all as to which terminal is what function. Does anybody have a table they have made or gotten from somewhere.
Thanks,
Dan
Old May 1, 2005 | 01:26 PM
roopert_bates's Avatar
The '727 is internally the same as the '730.
There are no wiring changes necessary.
I'm running the 727 ECM and routinely program the EPROM with BIN data for the '730.
Both '727 and '730 use the $8D Mask.
Hope this answers your question.
Old May 1, 2005 | 09:20 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
I think he is looking for a pin out comparison..
engerdan you have an email
Old May 1, 2005 | 09:22 PM
engnerdan's Avatar
Car: 88 Mustang GT
Engine: 5.0
Transmission: TKO
No that is not want I am looking for. I need the pin out for the 727 when you are running a 730 bin. Because the 90-91 vette has an extra sensor (oil temp) and some other stuff is different if I rememebr correctly.
I currently have the pin out for it to run a 90-91 vett bin, but if I wish to run a f-body bin I need a different pin out.
Old May 1, 2005 | 09:25 PM
engnerdan's Avatar
Car: 88 Mustang GT
Engine: 5.0
Transmission: TKO
Well looky there faster then I can reply to the first messase I got the answer I wanted.
Jeff- That was EXACTLY what I was looking for, now I am one step closer to a Ford running with GM brains.
Thanks Jeff
Old May 2, 2005 | 07:05 AM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
Thanks Jeff
No problem..
But roopert is also correct as the bins are very close.. there are a couple differences but I am basically runnning the AUJP F-body BIn in my 91 vette, although I have the oil temp sensor and vette timing in the BIN file
Old May 2, 2005 | 01:44 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Jeff could I talk you out of a copy of that? I'm taking my RS from carb back to EFI (StealthRam style) and I want to use a '727 so I don't have to wire as much through the firewall.
Old May 2, 2005 | 02:12 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
I will try to remember to either email it to you or post it on my website for access..
I got most of the info from the Gm Shop manuals and Ludis' website at one time
Old May 2, 2005 | 05:24 PM
-=Jeff=-'s Avatar
Engine: LT5
Transmission: ZF6
727-730 conversion
http://jeff.vettextc.net/ECM/
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
355tpipickup
Aug 19, 2015 10:02 PM
