Trying to connect to TBI ecm winaldl, no luck
Old May 8, 2005 | 03:11 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
After connecting and getting my Firebird hooked up to a laptop via aldl, I figured I try my go on a 4.3 TBI motor with winaldl. I cannot get the computer to connect, or even see any data from the aldl port with my bought aldl cable, that works in the firebird.
I have windows xp baud set to 2400, along with the ecm in winaldl set to the 288 ecm, and nothing. I can however pull codes from the car with the paper clip trick.
Is the data cable still M on the aldl port? What color wire am I looking for to be the serial data wire?
PJ
Old May 9, 2005 | 06:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Make sure both E and M are tied to the data line of your cable.
If it's a USB cable, make sure WinALDL is set to use 4800 baud and not 2400.
Old May 14, 2005 | 05:00 PM
Balael6's Avatar
Car: 1988 Formula
I do not have a usb cable, and what do mean e and m are tied together? Do i need the 10k resistor between ground and the aldl spot to make this work?
pj
Old May 14, 2005 | 06:18 PM
Mangus's Avatar
Transmission: T5WC
both pins E and M carry ALDL data, depending on the ECM. If your carries the data on E but your cable only reads from M, it won't work. Same with the opposite. Therefore, make sure your cable reads data from both pins. You can physically tie them together.
The 10K resister between pins A and B is only required if it's a 1227165 ECM.
Old May 14, 2005 | 07:04 PM
Balael6's Avatar
Car: 1988 Formula
Sweet, got it. Thanks guys. had to connect to pin m to find out that the o2 sensor is going south.
pj
BRoss99
Aug 10, 2025 05:08 PM
mddaniel
Sep 8, 2015 05:16 PM
bamaboy0323
Sep 3, 2015 06:07 AM
jer4251
Sep 1, 2015 09:04 AM
marcusaw
Aug 10, 2015 08:13 AM
