$6E (MAF) code, BLK LRN CELL shift oddity
Old May 9, 2005 | 08:52 PM
sphinx360's Avatar
I always thought the BLK LRN CELL in my TunerPro log referred to the LV8 cell # in the spark and AFR maps.
While working on a new tune, I found a change in the BLK LRN CELL and BLK LRN # but I can't find a mentionable difference in any other part of the data. The CELL # shifts from 1 to 0. The BLK LRN # goes from 128 to 136. The LV8 variable only changed by 1!
see attached log, sample 1750 to 1751
http://webhome.idirect.com/~mase1/mm66-1-s.csv
Why is it in the "0" cell with the LV8 reading 55 ? What variable is causing it to shift from cell #1 to #0? I need to understand that before I try to change the AFR in the "0" cell.
Old May 18, 2005 | 09:54 AM
sphinx360's Avatar
Anyone, Anyone?
Can someone at least confirm that the BLK LRN CELL #s correspond to the LV8 values in the AFR and SPARK tables?
Old May 18, 2005 | 11:46 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It depends upon how the option bit 0 of $C017 (option word 4) is set. If set to 0 then the airflow variable is used, if set to 1 then the LV8 variable is used.
RBob.
F-body driver
Mar 6, 2023 11:44 AM
Nick McCardle
Sep 10, 2015 08:36 PM
tonys91rs
Sep 2, 2015 07:07 PM
RyanJB
Sep 2, 2015 01:27 PM
