Scanning
Old May 16, 2005 | 11:13 AM
CriSSes's Avatar
Scanning
Scanning with Tunerpro RT (Autoprom also hooked up) and I notice that every time I start a session and connect, my idle drops from about 1,200 rpm to 800 rpm. This seems strange since my idle is set to 750. Why would it idle at 1200 when running on auotprom and then drop back to 800 when I start scanning?
Old May 16, 2005 | 01:25 PM
AlexJH's Avatar
Engine: 5.7L V8
What car/ecm are you running?
Old May 16, 2005 | 01:37 PM
CriSSes's Avatar
Sorry,
89 IROC, 165/$6E/arap
Old May 16, 2005 | 02:09 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I don't have a direct answer for you, however after you connect you should try putting the vertical switch back into the center position. This removes the 10K resistor and should restore the ECM to its normal operating mode.
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Corry
May 31, 2001 08:52 PM
Mark305TBI
Jan 28, 2001 11:20 PM
