ALDL Log Question
Old May 17, 2005 | 09:58 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
ALDL Log Question
Is there an easy way to put the ALDL log into a spreadsheet or another program to read it easier? Its a pain in the *** to read out of the txt file.
Old May 17, 2005 | 10:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Most likely can import or just open the file. Using Excel it will read in files that are either fixed spacing, comma delimited, or tab delimited (along with a few others). Try a file/open and select "all files" under "Files of Type". Then open the file. the Text Import box comes up and you can selected either fixed or delimited.
Being able to graph is cool too.
RBob.
Old May 17, 2005 | 11:53 AM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Sweet. I will give that a try. Thanks
Old May 17, 2005 | 03:11 PM
DM91RS's Avatar
Car: 91 RS
buzz............what kind of aldl are you using.......winaldl?
Old May 17, 2005 | 04:54 PM
buzz12586's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: 5 spd
Yea I am using WinALDL. It puts them out in txt format.
Old May 17, 2005 | 04:57 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
import it as either a comma or tab delimited file in excel. Which one depends on the txt file (are the field separated via commas, or tabs?)
Cornholio7979
Sep 20, 2018 02:31 AM
chazman
Aug 28, 2018 03:25 PM
89fast5oh
Sep 27, 2015 09:04 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
