Tunercat 8D
Old May 21, 2005 | 07:29 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Tunercat 8D
In the constants what is Inj offset volt. select [X=Battery]
Should I put a check mark, in case of low battery voltage.
Old May 21, 2005 | 08:03 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Anyone
Old May 21, 2005 | 08:55 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
When the box is checked, battery voltage is used to do the injector voltage offset lookup. When unchecked, fuel pump voltage is used instead.
That's my understanding of it, anyway.
Old May 23, 2005 | 12:50 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, that's exactly right. I use the battery selection myself. Partially because I'm using the other line to report feedback from my WB into the $8D datastream so I can data log it.....
ULTM8Z
Oct 2, 2015 01:25 PM
Grim Reaper
May 23, 2001 08:08 PM
Grim Reaper
Apr 20, 2001 10:40 PM
Grim Reaper
19
Jan 28, 2001 06:48 PM
