knocking make sense?
Old May 28, 2005 | 01:30 PM
2new2funny's Avatar
L98, MAF
zz4 cam
6* initial timing
TPS 1.55, MAF 67.83 g/s
arap advance curve
I did some datalogging and found 5 degrees retard on an acceleration burst at 2000 rpm while both integrator and blms showed 128 and load was 161.
According to the table, spark was exactly where it should have been at just over 32 degrees.
Why the knock and subsequent retard?
Is the solution to modify the advance table or to add fuel?
If I were to add fuel, wouldn't it then be rich?
Comments?
Oh! Why doesn't the tps match the maf table value at that point? (Should be 26 g/s in Table 2)
Old May 29, 2005 | 01:03 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Um, No? The voltages you see in the MAF tables are MAF SENSOR voltage, NOT TPS voltage.
Old May 29, 2005 | 08:05 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: knocking make sense?
Take some timing out first. The ARAP uses more then is typically needed.
RazorN8
Jan 7, 2022 11:44 AM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 07:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
gwade12
Aug 8, 2015 08:17 AM
