highest g/s is 160
Old May 28, 2005 | 02:26 PM
2new2funny's Avatar
highest g/s is 160
160 at tps reading of 4.69 (won't go higher) and at a load of 247 and 3400 rpm. The MAF table (6) indicates it should be 154. What's going on?
BTW At the other end of things in table 2, I get 2 to 3 times what's set in the tables. The car runs fine except for some knock as I posted earlier.
Old May 29, 2005 | 01:05 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
The voltages in your MAF tables are MAF sensor output voltage, NOT TPS voltage
Old May 29, 2005 | 12:04 PM
2new2funny's Avatar
I had a quick look at TunerPro and there doesn't seem to be this value recorded.
Does TunerPro have this capability?
Old May 29, 2005 | 05:39 PM
Car: 2000 BMW M5
Tunerpro RT reads out MAF grams/sec. It is simply using the MAF lookup table to translate the raw voltage from the MAF sensor into flow. You still can not correlate this to TPS voltage, thats entirely different.
Mark_ZZ3
May 24, 2018 01:02 PM
PurelyPMD
May 5, 2016 04:57 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
