WinALDL Logging Question
Old May 29, 2005 | 12:17 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I need to look at TunerPro 3.09 to do my data logging (4.0 was unrecognizable as a valid win32application...) But in the meantime, I'm using WinALDL.
My question is, when looking to adjust my tune, do I look at the Raw BLM/INT or the Sensor BLM/INT???? Raw looks good from 1200 to 3K (lean under 1200 and need to log above 3K) Sensor looks horrible at spots.... I am enclosing a partial table below.
Code:
SENSOR:RPM    RAW:BLM    RAW:INT    SENSOR:BLM    SENSOR:INT
925	          141         128	  117	128
950	          141         128	  120	128
1300	          128         131	  121	131
1275	          128         125         122	125
1775	          128         135	  123	135
1800	          128         129	  124	129
2225	          129         128	  134	128
2200	          129         128	  167	128
2150	          129         128	  204	128
1950	          130         132	  205	132
1625	          128         127	  211	127
1675	          128         133	  213	133
1625	          128         131	  219	131
1625	          128         128	  227	128
1750	          130         133	  231	133
2000	          130         130	  236	130
1850	          128         127	  252	127
1650	          128         131	  253	131
1650	          129         130	    1	130
1625	          129         131	    3	131
1625	          128         129	    7	129
1375	          128         130	   18	130
1300	          129         135	   19	135
1150	          130         134	   23	134
1075	          141         127	   23	127
950	          141         130          25	130
950	          141         127	   28	127
925	          141         126	   29	126
925	          140         125          30	125
975	          140         129	   35	129
925	          140         127	   40	127
975	          140         128	   43	128
975	          140         129          48	129
1025	          140         129	   53	129
975	          140         127	   55	127
1775	          130         142	   57	142
2025	          132         133	   65	133
1650	          129         127          66	127
1750	          132         136	   73	136
2525	          128         134	   95	134
2775	          129         128	   101	128
2900	          129         128	   101	128
2950	          129         128	   101	128
2050	          133         116	   102	116
2300	          132         126	   125	126
1525	          130         122	   130	122
1550	          130         128	   135	128
1475	          130         126	   140	126
1400	          130         138	   153	138
1375	          130         133	   157	133
1225	          131         130	   158	130
1100	          140         130	   159	130
1125	          140         130	   170	130
950	          140         124	   172	124
1050	          140         129	   173	129
975	          140         125	   175	125
950	          140         126	   177	126
975	          140         126	   179	126
925	          140         127	   185	127
1025	          140         128	   191	128
1000	          140         128	   196	128
975	          140         127	   203	127
975	          131         125	   208	125
2150	          131         135	   219	135
2050	          132         131	   230	131
1900	          133         131	   243	131
1875	          133         132	   255	132
Old May 30, 2005 | 06:42 AM
JohnL's Avatar
Are you sure you've copied these correctly and you're not getting a wrap that puts the headings on the wrong columns? I usually load my Winaldl logs in Excel so I can hide columns I don't want.
My sensor and raw BLM's and INT's are always the same AFAI recall.
And you should be able to get your columns to line up in your post by enclosing the section you want in columns by "["code] and "["/code] - but take the double quotes "" out for it to work.
John
Old May 30, 2005 | 09:29 AM
Captain C's Avatar
Car: 1985 IROC-Z
I copied everything from wordpad into Excel as well. I copied and pasted from Excel into the post. Thanks for the tip on lining up the columns in posts!!!!
I will try to start using TunerPro for data logging in the near future and see if that makes any difference.....
Old May 30, 2005 | 01:19 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Don't use wordpad first.
Open excel.
"open" the file and use tab delineated when asked for the import method..
It will place all data in the proper columns.
Old May 30, 2005 | 05:21 PM
Captain C's Avatar
Car: 1985 IROC-Z
Thanks for the tip. I have never used "import" for wordpad before, normally from an Acess file (or vice-versa)..... In fact, I only use wordpad for WinALDL as it is the default file system for it.
Old May 31, 2005 | 05:51 AM
JohnL's Avatar
It looks like there's something wrong with your copy of Winaldl, as you have BLM's from 1 to 255. I understand that this is impossible the way the GM binaries are coded.
I'd try downloading another copy and reinstalling it on your PC.
John
Old May 31, 2005 | 10:00 AM
Captain C's Avatar
Car: 1985 IROC-Z
I've just been using the Raw BLM/INT's to go off of. Some items look the same whether raw or sensor. I need to just take the time to use the datalogging in TunerPro. I wish TunerPro 4.0 would work on my computer but it gives me this "not a valid Win32 program" message. Seems like version 3.09 did the same thing originally and I don't remember what Idid to correct that......
I know I can still datalog with 3.09, but I wanted to see the gauges and changes for 4.0..... In the mean time I will reload a new version of WinALDL.
I imported a new datalog last night and the information came out the same way and it was more work that what I was already doing (Select all/copy/paste in Excel spreadsheet)
Old May 31, 2005 | 10:07 AM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Not sure i understand.
You don't need to copy and paste any data in excel.
when you save your file just remember where it is.
Then open excel.
select the file menu at the top and go down to open.
when the window opens go to the file type box and select all files.
then select the file you saved in the directory you saved it to.
it will then come up with the option to open with tab delineated, which should be the default.
just select the default options and the file will open already in columns for you.
BTW, I don't use raw data. ony sensors, flags and errors.
HTH
Old May 31, 2005 | 03:49 PM
Captain C's Avatar
Car: 1985 IROC-Z
Which version of Excel are you using? In 2003 you don't have the option of doing it that way. You have to go to tools/import in order to import the data. If you just click on open, it comes out really bad. Kind of like opening a .jpg file with Word. Also, you have to go through about 3 to 4 checks for it to open it in tab delineated format.
I save everything that is WinALDL based in a folder labeled the same (at least until I make an Excel file out of it). It automatically delineates everything into tab format when I paste it.
BTW, I'm a former USN (75-79) named Bill and I was just in Italy a couple of weeks ago...... Rome, Florence, Verona, and Venice.....
Old May 31, 2005 | 04:08 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I'm running several versions on excel.
At home here it is 2002 SP3
I have a file named 20030129_152908_log.txt
When I open excel I go to the top left:
I select file....then open
A window opens and I go to the folder where i have my file.
Then I go to the files of type at the bottom of the small window.
It normally is defaulted to "all microsoft Excel files"
I select "all files"
then my log.txt file will show up.
I double click on it and it automatically opens the "text import wizard" screen! "step 1 of 3"
I just select next twice and then finish.
I have been able to use it like that on all my different computers, even at work!!!
HTH
I just did a 600 mile trip around Sicily this weekend!!!
It was awesome!
I'm at 23yrs now. I don't want a real job!!!
CWO2 was ATCS
Send me your file and I can convert it and send it back!!!!
Old May 31, 2005 | 08:17 PM
Captain C's Avatar
Car: 1985 IROC-Z
Excel 2002 is different than 2003 in many ways. 2002 is closer to 2000 or XP than 2003. Has some nice upgrades in 2003, especially in PowerPoint. I have to admit I don't use 2002 that much, only at church...... Converting the files is no big deal, that's been done both ways and it still came out the same.
I re-downloaded TunerPro 4.0 and it installed correctly this time, don't think I got the whole file the last time...... I will start using it for datalogging and it looks like I will be able to open a blank Excel file and have it datalog directly to it. That will save me time all the way around.
I worked both the Terrier missile launching system and in my last year, the Mk42 5"/54 while on the USS Truxtun CGN-35. Been at my current job for 23 years (oil production, although I've run the turbines on our Cogeneration units. We've got some LM 2500's too...)
Old Jul 9, 2007 | 11:14 PM
1badz71tahoe's Avatar
Re: WinALDL Logging Question
John
Thank you John, i've been searching for hours, and finally figured out that i need to open it up in a more advanced program than excel.
- B
Cornholio7979
Sep 20, 2018 02:31 AM
89fast5oh
Sep 27, 2015 09:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
