Stopping forced knock test on 8063.
Old May 29, 2005 | 10:58 AM
kidcamarosc's Avatar
Ive been trying to do some tuning on my motor but haven't been able to get alot done due to Code 43 popping up every tunning run I try to make and it kills my performance. On my 8063.ecu file im using there are three constants that I think have to do with the "forced knock test".
Knock mph threshold-which is at 10mph
Knock rpm threshold-which is at 1000rpm
knock cts threshold-which is at 54 degrees C
If I where to bump the mph threshold up to 255 mph or so would that disable the forced knock test???
Old May 29, 2005 | 03:26 PM
JPrevost's Avatar
Car: 91 Red Sled
That isn't the knock test, that's for knock retard. It'll still pickup the knock but below those thresholds it won't retard the timing.
Take a look at the patch for the 8746 that disabled the forced knock test. It works and the code is very similar.
Old May 29, 2005 | 07:33 PM
Ok, thanks i'll check it out.
Old May 30, 2005 | 11:56 AM
I downloaded the patch but have no idea what to do next. I was looking at the thread about it but its basically a differant language to me.
Old May 30, 2005 | 02:52 PM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by kidcamarosc
...its basically a differant language to me.
Yeah, so learn it . I don't have your ecm, if I did, I'd help. So it's up to you if you if you want to patch it or swap to a different ecm.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
