Injector and cylinder vol
Car: El camino 70 ss
Engine: corvette lt1 94
I have the 6395 ecm and BJLK bin and lookt at injector flow rate
(per bank) it was 7.69 gram per second.when i calculate with the
formula a got 7.71 gram per second what is right valu??
Calculeted the cylinder volume(per cylinder)0.71675 the bin has
0.71 liter the 0.71675 is more to 0.72 liters what is right??
Car: 91 Red Sled
0D mask, good pcm
7.69 vs 7.71 is 0.02 which is less than 0.003% error. Not too shabby in my opinion. Also, there is error caused by other variables to just get it close and call it good.
There is sometimes a resolution limit in the code that will force you to use a value not "exact." Like for example; 8-bit values for SA are raw * 0.351567 . So if your base timing is 8 degrees you only have 7.73 or 8.08, obviously 8.08 is closer to what you want, so use it and move on. Everything is compromise, don't get hung up on decimal places.
.7.69 vs 7.71 is 0.02 which is less than 0.003% error. Not too shabby in my opinion. Also, there is error caused by other variables to just get it close and call it good.
