explain lv8 please
Old Jun 3, 2005 | 01:16 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
explain lv8 please
ok so i am really new to this what is lv8? and how is it meassured? and what not.. i see it in my spark table but is it like maf g/ps?
Old Jun 3, 2005 | 03:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The LV8 is basically a fake manifold pressure term so teh tables can be reflected in terms of engine load instead of just airflow. Its based on the MAF flowrate and the engines RPM. A given airflow at a low RPM can be a high load while that same airflow will be a lower load at a higher rpm.
Old Jun 3, 2005 | 03:36 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I placed a file that explains the MAF system in some detail on craig moates filemanager. Its located here:
http://www.moates.net/fileman/index....eous%20Uploads
its called 32B MAF tuning document
its intended for both 32B and 6E systems, as they are very similar.
read up on that, and come back with more questions!
good luck!
Old Jun 3, 2005 | 06:24 PM
JPrevost's Avatar
Car: 91 Red Sled
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Cacike
Aug 27, 2015 05:10 PM
