can't read memcal
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
can't read memcal
equip: Burn1 & HDR1 & Flash&burn
This is for those who can't seem to figure out why the can't read their memcal...when everything is installed correctly, but nothing you read to the buffer and save... has any values when you go to use it in a editing software.
MAKE SURE that the Chip Addressing and the Buffer Addressing are the same!!!
simple
the TGO search needs this post.
add any info if it would help nubz on this subject only
simple
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
my newbie observation is that this also applies to start address, end address, for both chip and the buffer. When I started using burn1, the buffer end address was set to 000000. I had to manually set it to 007FFF (for my 27C256). and make sure the end address for the chip address didn't change. maybe later I'll find out a better way to do it, but this is what it took to get started, after two days of putzing around.
