$58 and big injectors
Old Jun 30, 2005 | 02:40 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
Planning on switching to some big injector this weekend and looking throug the code I think I need change the following for a start...
BPW vs EGR (injector size)
KAPLL (to prevent switching fuel mode at idle)
KAPMIN (to prevent switching fuel mode at idle)
AE vs MAP
AE vs TPS
Inj. offset vs battery voltage
Anything more?
/N:
Old Jun 30, 2005 | 02:59 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I would seriously investigate your plug issue before I would go any farther along on the performance route.
Or did u find that u had bad injectors?
later
Jeremy
Old Jun 30, 2005 | 06:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: $58 and big injectors
AE vs MAP
AE vs TPS
Anything more?
That's a start, but, depending on how fussy you are, you might edit alot more, to include the VE tables, decay rates of the *choke* fuel, etc, etc..
Old Jun 30, 2005 | 11:35 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
This is a way to rule out the injectors...I have new p/h injectors from Racetronix laying........
I only have 1 set of plugs left and they cost around 7$ each here, anybody want to send a package or two? hint
/N.
Old Jul 19, 2005 | 03:56 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Ok ... here is what I had to do to get "almost" the same driveability as before.33->68 lbs injectors
Leave BPW vs Voltage the same, just used the same values between from 12 volt and up to get a flat curve.
AE tabels need a litte more work but I cut them by 50% and then I had to increase vs tps some...
Kapmin & Kapll to 0.520's....
I also had to rework the most of my VE table to get the same smooth driving I had before, the most significate change was in the 70-80kPa 1400-2400rpm area (light acceleration) I had to add alot or else I got a lean bog during light acc. I tried to cure this with AE but it didnt work.
Still more tuning to do...............especially with DFCO.......
Old Jul 19, 2005 | 08:54 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I've recently had great luck by just disabling DE, and DFCO, and using the closed throttle VE to get what I want. I'm not sure if it's due to going to a lighter converter, or I just missed previously getting this strategy right in the past..
Old Jul 20, 2005 | 12:20 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The problem I have is rpm is jumping up/dowm 4-5 times before it settelings.....I tried to lower closed TPS table but didnt get the results I wanted, but I will try disable DE and DFCO and do it again......
/N.
Bubbajones_ya
Jul 6, 2024 08:32 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
