PCM hardware question.
Old Jul 5, 2005 | 11:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Working with the $0D w/ 68HC11...
I was revisiting the A/D hardware handling in the code and I was wondering what exactly the function of the port D reg. is in regards to the A/D converter. 'Port D' is accessed each time prior to the A/D conversion of the selected channel.
Edit: I thought it might have been port E for a moment, but now im not sure.
Heres the code
Code:
; Lead in for A/D ROUTINE, Single and Multi-channel read
LEEAA	LDX     #L3000			;Index CPU reg.
	LDAA    #$07			;0000 0111
	JSR     LEF12			;Port D config routine
	LDAA    #$01			;Set A/D Channel, CTS
	JSR     LEEFC			;A/D channel routine
	LDAA    $34,X			;Get A/D results
	STAA    L082D          		;A/D cool temp
	LDAA    #$06			;0000 0110
	LDAA    #$01			;Set A/D channel, A/D TPS
	LDAA    $34,X			;Load ch 1 results
	STAA    L0192			;Save it, A/D TPS
	LDAA    #$01			;
	BSR     LEF12   		;Port D config routine
	LDAA    #$11			;0001 0001, Set A/D to multi-channel read
	BSR     LEEFC			;Go do A/D conversion
;-Get each of the results in
	LDAA    $32,X			;Get channel 1 results
	STAA    L082F			;Save it, ALDL switch voltage
	LDAA    $33,X			;Get channel 2 retults
	STAA    L009F  			;Save it, A/D transmission temp
	LDAA    $34,X			;Get channel 3 results
	STAA    L00A1			;A/D battery voltage
	BRA     LEEFB			;Bra to return
; Lead in for A/D routine, Multi-channel read
LEEE2	LDX     #L3000			;Base reg. address
	LDAA    #$14			;0001 0100, Set up for multi-channel read
	BSR     LEEFC			;A/D routine
	LDAA    $31,X			;Get channel 4 results
	STAA    L00A0          		;A/D TPS
	BRSET   L0050,#$01,LEEF6	;Bra if b0==1, sync. MAP sensor reads
	LDAA    $32,X			;Get channel 5 results
	STAA    L082E			;A/D MAP voltage
LEEF6	LDAA    $33,X			;Get A/D channel 6 results
LEEF8	STAA    L01F8			;A/D O2 voltage
LEEFB	RTS 				;Return
; A/D Routine
; Channel 0=
; Channel 1=ALDL switch voltage
; Channel 2=
; Channel 3=
; Channel 4=A/D tps voltage
; Channel 5=A/D MAP voltage
; Channel 6=A/D O2 voltage
; Channel 7=Force motor current
; Channel ???
; Channel ???
LEEFC	BCLR	L001A,#$02		;Clear b1, ERR 55, faulty PCM 11										;
	STAA    L3030			;Save A, A/D Contorl/Satus reg.
					; b7=Conversion complete flag
					; b6= -
					; b5=Continuous scan control
					; b4=Multiple/Single channel control
					; b3=Channel select D
					; b2=Channel select C
					; b1=Channel select B
					; b0=Channel select A
	LDAB    #12			;A/D wait for data timer counter
LEF04	BRSET   $30,X,#$80,LEF11	;Bra if b7==1, A/D conversion complete
	DECB				;-1
	BNE     LEF04			;Bra if !=0, continue
;-Here if A/D conversion failed
	BSET    L003A,#$01		;Status word, set b0=A/D failure
	BSET    L001A,#$02      	;SET b1, ERR 55, faulty PCM 11
;Here if A/D successful
LEF11     RTS				;Return with data
; Port D configuration routine
LEF12	BCLR    8,X,#$38		;Clear b3-b5, 0x3008, (PORT D data)
	ASLA 				;Shift left
	ASLA  				;Shift left
	ASLA 				;Shift left
	ORAA    8,X			;
	STAA    8,X			;Store it
	RTS				;Return
Old Jul 6, 2005 | 12:26 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Oh, origionally the subrountine LEF12 was called a 'delay' routine. But, given whats specifically in the code adn the large number of A/D channels, Id say it does just a *tad* more then provide a simple delay.
Old Jul 6, 2005 | 11:56 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I might be all wet here specifically but I've seen something similar in other code. Not sure which port it applies to (don't remember right now)
It may be that the serial controller is used to do the reads on the analog channels (or digital inputs too) and then switches back to another operating mode when done.
The delay is what keeps things in order while that switch in mode happens.
Old Jul 6, 2005 | 01:10 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Id certainly be willing to accept that explanation.
The thing that bothers me, though, that its very specific use of the port D reg. considering its a delay. Each A/D seems to have a unique 4 bit value thats written to b5-b2 before accessing the A/D reg. There are also at least 12+ unique A/D channels in use. I almost wonder if its used to configure a modified A/D converter that has more then the standard 8 channels that the factory HC11's had. On top of this, nothing else is done after a read. No other read/writes relating to serial controller. Is it possible that its being used as a general output? Wild *** speculation and conjecture but 2^4 = 16 unique channels
Old Jul 7, 2005 | 11:49 PM
JP86SS's Avatar
Those bits you referred to are control on the SPI.
I didn't have time to find what each of them do, but I'm hoping you can clear some fog with this help.
This was from the "F" series manual.
Old Jul 8, 2005 | 10:08 AM
AlexJH's Avatar
Engine: 5.7L V8
!SS is slave select (active low)
SCK is serial clock
MOSI is Master Out Slave In
MISO is Master In Slave Out
Old Jul 8, 2005 | 12:23 PM
Car: 88 Camaro SC
Engine: SFI'd 350
In what way is it being used here? Im lost...
Motorola gives an example of an external A/D interface and there its actually clear that the serial hardware is being used to communicate. Here, the SS, SCK, MOSI, MISO are just set and then an A/D read happens as though it where just reading the A/D hardware. For the routine LEEE2, its read in teh standard manner, but with all the other reads, the clusters of 4 bits are shifted over and stored at port D and then it does the A/D read and returns. There are also alot of channels, not just the usual 8 that motorola claims are free for use.
Old Jul 8, 2005 | 01:29 PM
AlexJH's Avatar
Engine: 5.7L V8
I don't think it is being used, it doesn't make sense the way they are using it.
Old Jul 8, 2005 | 02:53 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
I can't read code well, so I can't add any input that way. I do remember looking at specific parts on these ecms(f body, truck etc), just to learn the architecture, so maybe I can add two cents. I do recall seeing on some of these ecm's that they had another external a/d for more inputs. There is some specific chip somewhere that is an 'expansion' chip, if I recall correctly, and it was connected via the SPI bus. Maybe this is a piece of legacy code that was meant to address more inputs? I'll have to dig into Ludis's site some more and check out the schematics, but that last clip of info jogged some memory about an expansion on the SPI.
Old Jul 8, 2005 | 03:04 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Can it be used as a general output? It sort of bothers me that its used right before most of the A/D reads.
jwscab,
That was my thought, maybe its used to access the additional channels in the A/D somehow.
Old Jul 8, 2005 | 03:41 PM
AlexJH's Avatar
Engine: 5.7L V8
jwscab,
How is it wired on the outside? Do port D lines go to an external chip? It may be for an analog mux to allow for multiple A/D channels on a single ECM input.
Old Jul 8, 2005 | 03:49 PM
JP86SS's Avatar
I think I might be on to something...
Section 8.4 in the pink book
Code:
"When an SPI
transfer occurs, an 8-bit character is shifted out one data pin while a
different 8-bit character is simultaneously shifted in a second data pin.
Another way to view this transfer is that an 8-bit shift register in the
master and another 8-bit shift register in the slave are connected as a
circular 16-bit shift register. When a transfer occurs, this distributed shift
register is shifted eight bit positions; thus, the characters in the master
and slave are effectively exchanged."
There seems to be a comunication serialy taking place between the A/D converter and the processor. Thats why it looked tlike the shifts were a delay but in fact are transferring the reading to the processor.(or that's how I'm seeing it now)
The bits are shifted like stated above (very interesting how this works)
Must dig some more on it.
Old Jul 8, 2005 | 05:38 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Thanks a bunch for the input, guys.
Ill take a look tonight and see if I can see what it really does.
Old Jul 8, 2005 | 06:53 PM
ScotSea's Avatar
I seem to remember posting something about that routine on the GMECM mailing list a while back (on diy-efi).
Scot
Old Jul 9, 2005 | 12:52 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Ill google it and see what I can find
Donno, going to try to get one this weekend so I can poke and prod it.
Old Jul 9, 2005 | 01:56 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Based on what Ive seen so far, this seems like the most logical explanation given the fact that there appears to be only one internal A/D converter.
Scot,
couldnt find your post on DIY-EFI. Maybe it was lost in the crash?
88SS6SPEED
Nov 11, 2015 07:05 AM
sjorgens
Oct 1, 2015 07:54 PM
dbrochard
Sep 25, 2015 04:56 PM
Ian Irvine
Sep 4, 2015 08:08 AM
