O2 signal quality question (logs included)
Old Jul 10, 2005 | 06:13 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Is this typical for an o2 signal or is it somewhat jagged. It is a heated 3 wire delco in the factory manifold location.
Here is a CSV log.
http://home.houston.rr.com/lisfamily/7-10-05%20log.csv
Old Jul 10, 2005 | 10:35 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Same
Looks like all the logs I have.
Its such a low level signal that any grounding issues with the ECM or even ignition noise can make it look like that.
I don't believe its anything to worry about.
Old Jul 10, 2005 | 11:44 PM
eric305TPI's Avatar
I thought it was a grounding issue due to the fact the signal only drops into the upper 100's during decel fuel-cut while the wb reads free air o2 levels.
Old Jul 11, 2005 | 09:42 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: O2 signal quality question (logs included)
[QUOTE]Originally posted by eric305TPI
[B]Is this typical for an o2 signal or is it somewhat jagged. It is a heated 3 wire delco in the factory manifold location.
[QUOTE]
Normal.
The sampling rate of the scanner is much slower then the number of pulses going past it, so it's almost random as far as *where* in the pulse your reading.
On a good scope, and under the right conditions, you can see each cylinder firing, with a WB.
Frozer!!!
Jan 19, 2024 04:55 PM
zerogsx
Feb 6, 2016 11:29 AM
89fast5oh
Sep 27, 2015 09:04 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
