LO3, lt1 cam, fuel pressure?
Old Jul 22, 2005 | 04:36 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Engine: Stock 305 TBI
Transmission: Stock
Hey, what did most of you TBI guys end up running your fuel pressure after an LT1 cam swap? I'm tryin to get a ballpark to set it at for my tuning. Thanks.
Old Jul 22, 2005 | 04:24 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
You could probably get away with a solid 15psi as long as your pump can support it.
Old Jul 22, 2005 | 08:01 PM
JPrevost's Avatar
Car: 91 Red Sled
15 sounds fine. It'll run really rich at idle and part throttle open loop... even richer when in PE mode... unless you get cracking on the calibration.
Old Jul 23, 2005 | 11:29 AM
ajbutowicz's Avatar
Car: 1991 Camaro RS
Transmission: Stock
Ok, i've got about 13.5 right now, think that will work, or should i try gettin a little more range out of my AFPR? I really need to get money for my chip burning stuff saved up, i'm new to it all and had carb plans but decided to not burn even more money doing that... So i just want a good baseline, one more thing i dont have to worry about screwing up when i start figuring this out.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
