Prom Help...
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Prom Help...
I have a 88 ECU out of a 'Burban. I want to read the bin file in it, but I can't find the chip in the listing.
The programmer is a TOP2005, anyone used it before? I could really use some help here.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You just need to know the ECM number, I bet the last 4 digits are 7747, if they are all you need is the 42 ecu file, which is all over the place.
