Rbob
Old Aug 13, 2005 | 08:41 PM
ULTM8Z's Avatar
Rbob
RBob, would you mind taking a look at this AutoXray data? Or anyone else who is willing for that matter!
I finally got some spare time this weekend.
Taking your suggestion starting off with a stock AUJP.
Originally posted by RBob
Make adjustments according to how the engine is running. Keep increasing the idle O2 terms 50mV at a time. Observe how the engine idles. There should be a sweet spot, then as the idle O2 values are continued to be increased the engine will get a little rougher.
RBob.
Here are the idle O2 terms:
Code:
L8496:  FCB     136     ; 600 mvdc, FAST O2 R/L THRES AT IDLE
L8497:  FCB     136     ; 600 mvdc, UPPER ZERO ERROR O2 AT IDLE
L8498:  FCB     128     ; 570 mvdc, LOWER ZERO ERROR O2 AT IDLE
Should also zero out this one (no air pump, right?):
Code:
L849D:  FCB     23      ; 100 mvdc, DIFF R/L WHEN AIR DIVERTED
And set the air to always divert (set to 255):
Code:
L839A:  FCB     73      ; IF COOL < 14.7C, DIVERT
I did all of that (including adjusting the injector constant for my 24 #/hr injectors.
Basically, I started at 200 mV and worked my way up to 850 mV (man, did this thing ever smell rich at 850 mV!! ).
I exported and compiled all of the AutoXray data into an Excel spreadsheet for convenience. So whoever wants to see it, please post here or send me an e-mail and I'll forward the file to you.
Anyway, if you guys have some spare time, it'd be greatly appreciated!
Edit: the file is only 187 kb, so it's even dial-up friendly.
Rocket-Doc
Nov 14, 2015 02:08 PM
CORV3TT3
Aug 23, 2015 11:26 AM
ULTM8Z
63
Sep 12, 2005 09:08 PM
jwscab
Sep 16, 2004 07:40 PM
jwscab
Sep 10, 2004 08:49 AM
