Code 43 possible causes?
Old Aug 16, 2005 | 08:11 AM
IroczInOz's Avatar
1990 Chev IROC Code 43 will not go away.
What should I be looking for.
43. Low voltage at electronic spark timing circuit
The above problem MAP cars don't have the EST box as the MAF cars. So what voltage should I be checking.
I think it might be something else, performance of the car seems good so it does not look like it is effecting it.
Any tips on what to look for to get this code to go away?
Old Aug 16, 2005 | 10:15 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Is the single wire weatherpack plug (brown wire) disconnected for the distributor?
Old Aug 19, 2005 | 07:51 AM
IroczInOz's Avatar
Nah it is connected, wish it was that easy but it never is.
Old Aug 19, 2005 | 11:24 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Not sure if it applies but code 43 on $8D (SD MAP car) is indicated for the spark advance knock test.
Your knock sensor may be the problem and is not giving a response to the added spark during the test.
Might want to check it out and see if is changing when detecting knock. Do some datalogging while accelerating hard and see if any knock counts are showing up. If there are none then it possibly needs to be replaced.
From looking at the code values, the detected voltage levels should be between 3.54 Volts maximum and 1.41 Volts minimum during the test to NOT set the error.
The resistance of the knock sensor changes when knock is detected to control the voltage level.
Old Aug 19, 2005 | 06:44 PM
IroczInOz's Avatar
Awesome I will check that out!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
