tunerpro rt 4.0 a no go.
Old Aug 24, 2005 | 03:38 PM
Ronny's Avatar
tunerpro rt 4.0 no go
need some help.
first time use.
trying only to datalog.
went tools-datalog-set up and added definition file for 7747_42.ads. comm type setup max232. dont know what that is but i was told to do by a member. also set com port 1.
my RS USB/serial is com port 1.
when i bring up program(first) i then turn on ign(second) it says aldl "connected" but no data with engine off(no tps reading) and if i start car nothing as well. still says connected. i will print and read "help" this evening.
did i miss a step?
__________________
Old Aug 24, 2005 | 06:55 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
That should do it, assuming your COM port is indeed COM1.
Old Aug 25, 2005 | 10:11 AM
Ronny's Avatar
i checked after postiung. it is com 1 on RS serial usb adapter. windows XP.
Old Aug 25, 2005 | 11:12 AM
Mangus's Avatar
Transmission: T5WC
Does winbin work for you? I have a 747 on the bench that works great.
Old Aug 25, 2005 | 01:48 PM
Ronny's Avatar
i was using win ALDL and that connected to RS serial/usb. confirmed RS cable is on com port 1 as is laptop. only tried to connect 3 times now so maybe i am doing something wrong. will try diff startup combinations. think i should run your program after car is running or ign on? i think i had RT up and then i turned on ign.
Old Aug 25, 2005 | 03:15 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Ron - I have had issues as well. The data will show up but nothing on the graphs. I just go back to WinALDL which has no issues.
Old Aug 25, 2005 | 03:57 PM
Ronny's Avatar
well i need the pulse width of injector to determine if too small to function at idle. i have seen that can be patched into win ALDL but not confident i can pull it off.
ZZ3Astro
Aug 13, 2019 12:57 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Quzyle
Oct 15, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
shanelique22
Sep 24, 2015 06:30 PM
