z69's WB02 Hack
Old Aug 25, 2005 | 08:24 PM
BenDoe91z28's Avatar
z69's WB02 Hack
What program is used to read the output for the wideband o2. I have the demo of TTS datamaster, and tunerpro, but I dont see where the output is put to. Is there a special menue where I can select which outputs I want?
Old Aug 25, 2005 | 10:46 PM
Z69's Avatar
Z69
It's in the included txt file where the output is at.
The included ads with TP doesn't have the aldl word 37 in it.
You have to add it. Or wait for the people working on the 8D ads release to finish. The included ecu file has a number of aldl words included in the constant section. That way people could move the afr else where if desired. I also included the 8D aldl list in the zip so people might take a stab at hex editing. I was told that datamaster will display word 37 as Learned IAC. The anht hac calles it minimum iac. DM displays it as an integer and it isn't used much so it seemed like a good place.
I've been mailing the s19 out when requested with the warning that there is a possibility of it not working correctly. There's only about 6-8 people with the patch currently.
The reason I haven't released the whole thing publically yet.
Is due to the fact that I don't want to release it w/o a final test bench run to ensure a typo did't creep in during the final edit of the asm. I had a couple that prevented it from assembling. Forgot a $ & an 8 for the new aldl location was one. My notes have the locations as in the bin...
Managed to cut and paste it into several other bin patches. I plan on AUJP, S_aujp-all, AXCN,ANHT,AXCR, AXYC, AXXC-D-F.
Old Aug 27, 2005 | 11:56 PM
Z69's Avatar
Z69
The response by the non AUJP users is so overwhelming
I may not even bother with the other bins........
Old Aug 28, 2005 | 10:18 AM
Sorry, I've been trying to find the time to research before I make the assumption that the scanner out there doesn't exsist yet.
Moates scanner produces a word 37 display, but i havn't gotten to try it yet, and it only works in DOS.
I am completely oblivious to hex editing and this whole hacking thing.
ZZ3Astro
Aug 13, 2019 12:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
z28joe2
Sep 28, 2015 05:54 PM
shanelique22
Sep 24, 2015 06:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
