Where to find MEMCAL - PROM?
I've got an 89 Vette with a 383 that I'm custom tuning (your site is an AWESOME resource). I'm using a combination of EPROMS and a ROMULATOR to get everything dialed in and had it 98% there when the SES light came on, it wouldn't hold idle by itself and the AutoXray wouldn't connect to the ECU.
I swapped the ECU and got the same result, so I went to the factory manual. All signs point to the MEMCAL. It's an Ed Wright part with two chips on it, besides the PROM.
Not wanting to spend a whole lot of money on the 'brains' that I'm just going to throw away, any idea where I can buy the memcal parts? (google and Jameco have no knowledge of the other two chips: CTS9930/16055376BV and CTS0105/16055375BV...I get the impression they handle a limp home mode if something goes wrong with the prom.)
OR, am I missing something ovbious?
I dont have confirmation on this yet, but maybe a direction for you to look in and confirm.. MemCal packs on some Carriers I have seen replaced with DIP-Resister Arrays. I have not actually checked the package, but for a 7165 $6E Prom Cartridge ( carriers) The Mem Cal has been replaced with resisters in such after market products as HyperTech , superChip , and a few others I dont know who made.. Im not sure if they put resisters there to eliminate the Limp Home Mode.
I think you're right. I seem to recall more 'stuff' in the stock memcal. This one is an Ed Wright part. Infortunately, I can't seem to put my hand on the stock carrier, so I can't tell if the problem is the PROM, or the other chips (resistor array).
Since I just desoldered the original prom, there could be a contact issue. That should pretty well be ruled out after the ZIF socket gets here next week.
I know with no Chip, I can still run my car so long as those Limp home chips are installed. It starts and runs fine, just a steady engine light. Im looking to see if I have your chips..If so its possible to send them to you.
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
try tpiparts.net i ordered one from there for my car. only problem is the corvette ones are a bit more expensive than the trans am tpi memcals
I picked up a chip-writer off ebay, and with Moate's ZIF adapter and a couple of known new 512kb EEPROMS got the car running reasonably well. Craig did a helluva job getting me the stuff, ESPECIALLY in light of the fact he was in the path of Katrina at the time.
Now if I could just get the transmission to stay together!
Hotrodboba400
Dec 10, 2019 07:07 PM
