Can I burn 165 info onto a 730 PROM?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I know they're different since 165 is MAF and 730 is MAP, but I bought an engine that came with a modified chip. I want to take those tables and use them with my setup (730). So is there any way I can take that info and burn it to the 730 or is it not even remotely compatible?
Car: An Ol Buick
Engine: Vsick
Re: Can I burn 165 info onto a 730 PROM?
You could use some of the numbers to get some rough values for timing, ie 0 LV8 being no load (20 K/Pa) and 256 being 100 K/Pa. the math for going from gm/sec to K/Pa would get stagering, IMO.
