Embedded Lockers, HUD, and the Ultimate TBI code
Old Oct 13, 2005 | 04:17 PM
  #151
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by Dewey316
Rbob, since this will be ROMless now, would a ECM with a bad PROM socket be ok? I have a spare ECM laying around, works fine, I replaced it because the chip would not seat well anymore. For this setup would this work? That way I can leave my current ECM in the car, and ship you the spare?
<--- can not solder for his life.
Yes, that ECM will work. The ECM little board which has the EPROM and CALPAK on it is removed and replaced with the Embedded Lockers board. The CALPAK and EPROM (a larger size with the UTBI code on it) is placed into the Embedded Lockers board. Machine pin sockets are being used for these parts.
RBob.
P.S. some of the parts arrived today. . .
Old Oct 13, 2005 | 05:04 PM
  #152
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Thank you sir.
I am getting excited. I have been dreaming of Lockers, for years now, but know I couldn't make it. Now I will end up with lockers on roids!
Old Oct 13, 2005 | 05:43 PM
  #153
Teeleton's Avatar
Car: 89 S10 Blazer
Engine: Built 4.3L V6 TBI
Transmission: Built 700R4
Axle/Gears: 7.65/Zexel/3.73
Any projections on how many units this first run is going to be?
Teeleton
Old Oct 13, 2005 | 06:00 PM
  #154
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
i will send u my ecm (8746) to test it on its a spare so u could take your time w/ it till your ready to ship them out then i will place my order and u can send it back. and u say your making it so the video card dosent have to be too good....how good is that cause my laptop is stoneage as in 250 mhz?? thanks
John
Old Oct 13, 2005 | 06:33 PM
  #155
JPrevost's Avatar
Car: 91 Red Sled
John
250mhz stoneage? Geeze, I'm only 24 and my first computer was a 486 66mhz Compaq Presario!
I don't know what the min requirements will be. I haven't tested the software on anything other than my laptop but like I said, I've been dumbing the graphics down a bit and trying to re-organize the code to be as efficient as possible. The hardest part is the fact that there is a LOT of data to process. We're not talking about just 20-40 bytes every tenth of a second. We're looking at 200 times as much data as the normal 160 baud ALDL and over 4 times as much data as the 8192 baud ALDL! I'll be continuing the software development just like Mark has done with TunerPro.
I have a pII 400mhz machine I'm putting back together to do some testing and RBob has a slower machine that'll get tested. I might even attempt to run this on a win 95 p75 thinkpad. Though I doubt it'll work with less than 200mhz.
Old Oct 13, 2005 | 11:44 PM
  #156
Teeleton's Avatar
Car: 89 S10 Blazer
Not that you need my help, but if you're having problems writing the datalog out fast enough, write it to a buffer in memory, and then dump it all to disk in a large write every so often instead of a bunch of little writes.
Teeleton
Old Oct 14, 2005 | 07:28 AM
  #157
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
My first one was an AT&T 8086 with an 8 bit VGA card. Also had a soundblaster on it, too.
As long as you keep XP off it the slower laptops run fine with most things. XP does not play nice with my PII366 laptop. Even causes the cooling fan to stop turning on so the computer comes to a grining hault.
Old Oct 14, 2005 | 01:27 PM
  #158
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I had one of those AT&T ones too, just had a big 5 1/2 floppy drive, then later I installed this crazy new hard disk thing. It fit in a 5 1/2 bay and had a panel on the front with flashing lights. Capacity was probably next to nothing.
Old Oct 14, 2005 | 06:30 PM
  #159
JPrevost's Avatar
Car: 91 Red Sled
Teeleton
That isn't the issue. Although having the buffer flushed to the file still hasn't been tested yet. If the program is shut down incorrectly it won't save the data and that can be really annoying. It's easy enough to implement, infact I might as well put that in after I post this reply.
As for the graphics. It's 80% there. I've lowered the processor power by a LOT although the install is nearly 20mb . That's what I get for having active x and LabView . That includes the LabView run-time files so it's not like my program is bloated. It's actually really lean as it should be considering I've spent HOURS working on just speeding up the code.
I tested it out on my system; p4 2.4GHz notebook (crappy and slow EVERYTHING ELSE)... consumed only 6-20%CPU, 23Mb Ram, and 17Mb VM. Keep in mind that was playing back a file full of checksum errors, displaying the HUD screen (most graphical intense), and having opened a datalog file that was nearly 8mb. It really depends on how big of a file you playback/record. Not displaying the HUD screen and having a different "tab" on top will change the requirements.
All of my free-time is tied up into getting things ready for release. I'm not even finished with the wizard software although it's code platform is all setup and ready to rock and roll. Very easy to modify and get that done. I expect no more than 2 days to finish it up into a final release. The HUD software on the other-hand will take a little longer. I'm shooting for Halloween but again, no expectations. Worst case is I'm not totally ready but RBob is and I'll just release the software as is. Even as it stands it's very useable and functional .
Old Oct 14, 2005 | 07:00 PM
  #160
Car: 88 Camaro SC
Engine: SFI'd 350
I had twin 5-1/2 20 meg Seagate MFM hardrives and later a twin bay 35 meg IBM unit. Man was that a boat anchor.
P4 2.4 GHz slow? My old 2.0 would run Doom&#179 with a good video card. Also, in this day and age, 20 megs is nothing. The power needed doesnt sound overly excessive, either.
Old Oct 14, 2005 | 07:05 PM
  #161
JPrevost's Avatar
Car: 91 Red Sled
As in slow video card, slow HD, slow ram (and shared by video card), slow fsb, slow pci perfs. It's a slow machine considering it's advertised as a desktop replacement. Graphics card is an SiS M650. M standing for modile meaning it's SUPER slow .
Old Oct 14, 2005 | 07:10 PM
  #162
Car: 88 Camaro SC
Engine: SFI'd 350
Sounds like my old desktop, with the exception of the video card. That shared memory thing is complete BS.
Old Oct 14, 2005 | 08:08 PM
  #163
JPrevost's Avatar
Car: 91 Red Sled
Tell me about it. I bought 512mb but it's only got 448mb (64mb dedicated to the video).
Old Oct 16, 2005 | 02:42 PM
  #164
sp63
Guest
Posts: n/a
so. after reading this thread im pretty glad i havent bought a carb yet, OR bought the tbi tuning stuff yet. the way this looks, im gonna stick with the tbi and go with your alls product.
so long as it is slated to work with
a 1992 camaro rs 305tbi auto.
Old Oct 17, 2005 | 11:09 AM
  #165
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You'll still need the tuning hardware, and software. This board only allows you to datalog fater and use the new U-tbi code. Still need to burn chips.
Old Oct 17, 2005 | 12:23 PM
  #166
JPrevost's Avatar
Car: 91 Red Sled
Or get a prominator/romulator/ostrich (the later two shouldn't be used as a chip replacement for long periods of time).
Old Oct 19, 2005 | 06:18 PM
  #167
DM91RS's Avatar
Car: 91 RS
JP...........this is an attachment that you posted on the thread " Dyno tune time...finally"
Is this the kind of graphs that we can expect with the lockers/hud setup?
Hope so
DM
Attached Thumbnails Embedded Lockers, HUD, and the Ultimate TBI code-bill1tm.png
Old Oct 19, 2005 | 08:06 PM
  #168
JPrevost's Avatar
Car: 91 Red Sled
Very similar.
Old Oct 20, 2005 | 03:55 PM
  #169
DM91RS's Avatar
Car: 91 RS
Thanks JP...........the graphs are going to be very useful.
How is the software coming?
Old Oct 20, 2005 | 08:05 PM
  #170
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
I got all of you guys beat. We used an 8086 running the
PICK OS with 8 I/O devices hung on it doing bsuiness accounting and parts inventory.
Old Oct 21, 2005 | 02:02 PM
  #171
Teeleton's Avatar
Car: 89 S10 Blazer
Anyone else notice that this thread is barely a month old and already has over 3000 views? I think everyone and their brother is checking this thread daily for updates.
Teeleton
Old Oct 21, 2005 | 04:48 PM
  #172
Engine: 305 tbi l03
i check it about ten times a day at least just to see if they have said okay now taking orders for first 30 boards...cause i gotta get in on em.
Old Oct 25, 2005 | 05:40 PM
  #173
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
any updates?
Old Oct 25, 2005 | 07:08 PM
  #174
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by robertfrank
any updates?
Yes, things, items, and stuff is moving along (I know that sounds strange, but it is a good way to put it). Jon and I have been meeting to work out how the released HUD and tuning software will look and operate. Jon has set up the HUD software to use one of three display resolution modes. Along the lines of 8000x600, 1024x768, and a higher resolution (please don't quote me on the exact xy values).
This allows the software to be used on various levels of laptops. Jon is also working on MPG display's, for instant and trip MPGs, then trip miles traveled. There are 3D graphs for VE, SA, and knock information. Another tab for displaying the AE criteria. Delta TPS%, delta MAP, then the AE PW's from each. Everything required for tuning and evaluating engine driveability parameters. The HUD really works, and is a great part of the Embedded Lockers product.
From the hardware standpoint I am sitting on a pile of industrial grade parts. Industrial being the temperature range of the devices. This way the Embedded Lockers setup will operate at automotive interior temperature ranges. I am expecting the bare PCBs any day now. They were ordered ca. 1.5 weeks ago. Arriving any day this week will put them right on schedule.
The PCB boards are double sided, solder masked on both sides and silkscreened on top. Once built and tested they will be conformal coated. This is for reliability purposes, jsut like the ECM they run in.
Once I have PCBs I'll build and test one. Then get some out to beta testers. Jon and I will be testing along with another. As they are being checked out in live vehicles I'll build and test additional units. Once things look OK from the testers, the Embedded Lockers will be released for sale to the public.
A lot of work has already been completed: ECU file, board layout, prototyping and the testing of the design, the TBI code is tested and ready. Work is still progressing with the HUD (more features) and documenting the calibration table parameters.
I went a little long on this post, but most important is that you the reader, understand that this product is happening. It is real, and it will be released in a short of time frame as possible. It will be a good product, one that works as advertised.
RBob.
Old Oct 25, 2005 | 07:22 PM
  #175
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Good Job guys
Originally posted by JP86SS
Makes me want to go TBI
or
Go buy a car with TBI just so I can play with the new toys.
Reading this just made me say it again !!!,
Man this sound so cool.
Two thumbs up
Old Oct 25, 2005 | 07:25 PM
  #176
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
Is the HUD software compatible with the old lockers design?
Old Oct 25, 2005 | 07:34 PM
  #177
one more question that i have is will this be sold on craig's (www.moates.net) website or will you guys be going independant on this?
Old Oct 25, 2005 | 07:57 PM
  #178
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Embedded Lcokers HUD is not compatable with the original Lockers board. Even if it was it would not be compatible with any of the stock TBI code.
RBob.
Old Oct 25, 2005 | 08:05 PM
  #179
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: Good Job guys
Two thumbs up
Thanks for the thumbs up. Another aspect of the Embedded Lockers product is that a TBI equip'd vehicle will run as though they are port injected. The UTBI code is leaps and bounds beyond stock TBI code. It really makes that much of a difference.
At the moment independent. Once the product is available and selling there is the possibility of having a distributor(s).
RBob.
Old Oct 25, 2005 | 08:11 PM
  #180
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Re: Re: Good Job guys
Speaking of which, RBob how will your Ultimate TBI code react to say the edelbrock TBI-MPFI conversion. Any chance for us guys looking to PFI a TBI engine without a massive harness rework and an ECM change?
  #181
Engine: 5.7L TPI
RBob.
oh yeah, different firmware.
Old Oct 25, 2005 | 08:22 PM
  #182
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
This is so coool!
Old Oct 25, 2005 | 09:12 PM
  #183
okay rbob last one for now,by using just the UTBI code how should my car run? as in will it run better before the custom tune?or will it be the same?
Old Oct 25, 2005 | 11:02 PM
  #184
Teeleton's Avatar
Car: 89 S10 Blazer
Not sure if you have beta testers already lined up or not, but I'd certainly like to test one. Got to thinking about this earlier today, but I assume the cylinder select parameter is still present in the UTBI code?
Teeleton
Old Oct 26, 2005 | 06:27 AM
  #185
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: Re: Re: Good Job guys
The Embedded Lockers system will work better then the Edelbrock '7747 tune. This is just from using better code, data logging, and tuning software. The Edelbrock setup uses the Magneti-Marelli Pico injectors which are claimed to be a 'fast response' injector, and are a saturated type. This is from their web site (M-M's and Edel's). How much faster then a standard port injector I don't know. Even a little faster will help with the doubled firing occurrences.
RBob.
Old Oct 26, 2005 | 06:40 AM
  #186
RBob's Avatar
Car: check
Engine: check
Transmission: check
It would depend upon the actual engine and transmission. The UTBI code release will have an '85 Camaro 305 LG4 with 350 injectors (ORG/BLK) and an auto trans tune in it. That may be close enough to work in an LO3, maybe bump the BPC a tad if still using the 305 injectors.
The main claim to fame with the UTBI code is the new functionality and improvements. Large high resolution VE tables make a world of difference. Same with larger SA, AE, PE, and a bunch of other tables being expanded. The IAT/CTS blending, and AE compensation vs RPM table.
I'll put you down as being interested as a beta tester. Yes to the cylinder select parameter. It is present, but in a different form then the stock TBI code. Instead of 4, 6, 8 (the actual # of cylinders) it is a ratio to 8 cylinders, with 8 cylinders being 256 (truncated to zero in the calibration table). Then 128 for 4, 192 for 6, and 160 for 5 (any Audi converts out there?).
RBob.
Old Oct 26, 2005 | 08:08 AM
  #187
Car: 88 Camaro SC
Engine: SFI'd 350
Just out of curiosity, how did you handle the sync AE? Is it still represented as a dutycycle like teh stock code? Does this table also double as the conversion for the AE dutycycle to actual pulsewidth?
I take it this was done to tighten up the # of instructions in the routine? I thought of eliminating it as well to free up a few more instructions.
Old Oct 26, 2005 | 11:41 AM
  #188
RBob's Avatar
Car: check
Engine: check
Transmission: check
The AE starts with the PW vs delta TPS and PW vs delta MAP table lookups. These two values are added together along with the IAC opening PW being added in.
This AE PW is compensated by the AE vs RPM table. A table value of 128 is neutral, no change to the PW. A higher value increases the PW, a lower value decreases the PW.
The resultant PW is then compensated by the AE vs CTS table. The final PW value is then added to the synchronous PW.
I made the code cleaner and smaller. Just worked out better this way.
RBob.
Old Oct 26, 2005 | 12:04 PM
  #189
Car: 88 Camaro SC
Engine: SFI'd 350
Interesting...
I rolled it in as a duty cycle to keep it linear and then multiplied it in with the DRP to get the actual PW. I guess the table serves a dual purpose of translating it into a PW as well as providing flexability with how much is applied at each RPM.
Old Oct 26, 2005 | 12:28 PM
  #190
RBob's Avatar
Car: check
Engine: check
Transmission: check
Interesting...
Yes, the whole AE scheme is interesting. With stock code the AE fires 80 times a second, with no regard to the RPM. This has the affect of providing more fuel per cylinder at lower RPMs. Then as the RPM increases the same async AE PW delivers less fuel per cylinder.
This coincides with an engine at higher RPM not requiring as much AE. However, I found that a AE vs. RPM table was still needed. Without it I was unable to have enough low RPM AE while not having too much high RPM AE.
The RPM affects the AE requirement due to the airflow. Higher RPM provides a higher airflow, pulling the fuel through the manifold. Low RPM has low airflow and the fuel likes to coat the interior of the manifold.
By changing the AE from async pulses to adding it into the sync fuel pulses, the same AE PW at any RPM will provide the same fuel per cylinder. This makes the AE fueling flat. The AE vs. RPM table is now used to add AE fuel at lower RPMs and remove AE fuel at higher RPMs.
The reason I went with adding the AE to the sync fueling was to guarantee a smooth and consistent delivery of AE fuel. I was surprised at how well it works.
RBob.
Old Oct 26, 2005 | 01:39 PM
  #191
Engine: 305 tbi l03
just wondering why u taliored this to a carbed car when its code to make the tbi run better?? How much adjusting will probably be needed to run in a upgraded l03 (cam, 081 heads, edelbrock intake, lt headers full exaust) cause this will be my first tunning process and i dont know if it will be easier to learn w/ the UTBI code or the original tbi code. since my engine wont be very stock anymore i imagine both would be pretty difficult.
Old Oct 26, 2005 | 02:05 PM
  #192
RBob's Avatar
Car: check
Engine: check
Transmission: check
The code was actually tailored to run a warmed over 327 in a 1st gen car. The LG4 is just a test mule before the code goes to the 327. Testing after code changes starts on the ECM bench, goes to the LG4, then on to the 327.
The UTBI code has also been run on a 330 HP(?) GM Vortec crate motor. And will be run on a 355 Trick Flow headed and cammed engine in another vehicle as a beta test.
As for tuning, it will be easier with the Embedded Lockers system then on any of the GM TBI ECMs. One part of the HUD software uses the BLM values (or WB in open loop mode) and generates corrections to the VE tables. These corrections can be viewed in a 3d surface graph and hand adjusted.
They can be applied to the current bin with the corrected one becoming a new bin. Jon is working on a few other areas that will aid the user in tuning. Don't want to say too much, yet.
RBob.
Old Oct 26, 2005 | 03:39 PM
  #193
Dewey316's Avatar
Car: 1990 Camaro RS
RBob.
I happen to have a 2.2L Turbo, and a 2.3L N/A 5cyl motor...hmmm.
Nothing else to really contribute, other than I can't wait. I am going to do some more stuff to car here shortly, so I will really get a chance to see the UTBI code in action. I can't wait.
Old Oct 26, 2005 | 09:22 PM
  #194
Car: 88 Camaro SC
Engine: SFI'd 350
RBob.
This was also the same stratagy used by GM in the later P6's. While the TPS AE still works in a similar manner with async only, but with other improvements like a temp based filter coeff (really wanted that with the C3). The MAP works the same way you have yours. There is a table of correction factors vs. RPM. They provide the correction based on the period of rotation, but the corrections taper off below 1200 RPM to lessen the AE somewhat at low RPMs.
Old Oct 28, 2005 | 02:14 PM
  #195
RBob's Avatar
Car: check
Engine: check
Transmission: check
PCBs arrived. . .
dimented24x7: the UTBI code has a filter coefficient vs CTS lookups to individually lag the MAP and TPS (table for each a MAP and a TPS coefficient). The lagged values are then used for the AE PW vs delta MAP & delta TPS lookups.
RBob.
Old Oct 28, 2005 | 04:45 PM
  #196
Engine: 305 tbi l03
do u guys for see this being out by Xmas time if the beta testing goes good w/ few snags?? im getting so anxious i cant stand it almost and i dont even know how to tune ive read and read but never took it from paper to real world which is a large step but i think i want to make it w/ this code!!!
Old Oct 28, 2005 | 05:22 PM
  #197
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
PCBs arrived. . .
RBob.
YEAH!
Old Oct 28, 2005 | 05:56 PM
  #198
JPrevost's Avatar
Car: 91 Red Sled
The GUI is nearly done but the wizard hasn't gotten attention for over a week.
One program now instead of different versions for different resolutions. There will be a more graphically intense version later down the road. Right now it's about getting some real-world testing with the new hardware.
Old Oct 28, 2005 | 09:41 PM
  #199
RBob's Avatar
Car: check
Engine: check
Transmission: check
It runs. . .
Breaking news. . . built an Embedded Lockers board up and installed it into an ECM. Tossed it on the ECM bench, plugged in the latest cal for the ElCamino, and it RUNS!
Tomorrow (Saturday) I'll put that ECM in the truck while out fetching parts. Both furnace stuff and going to the JY for some ECMs. Will build up more Embedded Lockers boards into ECMs to get out to beta testers.
Jon and I still have some work to do, but nothing major. Oh, pic's too, I tried to take some tonight but lost the sunlight. Later this weekend.
justlearning, it won't be much longer. I really do want these available for Christmas. For all: getting the hardware squared away was key. With that in place the Embedded Lockers system is usable. Updates for the calibration data document, ECU file, UTBI code, and HUD will only be a Web site away.
RBob.
Old Oct 28, 2005 | 09:50 PM
  #200
Engine: 305 tbi l03
i got an ecm 8746 from a 91 RS tbi that u can use i will even pay to ship it to u cause i would want u guys to install the board anyway when i purchase one. you guys can beta test w/ it all u want as long as u keep it close so that i can get it back w/ the board i purchase and it stays in good shape cause it will go into my daily driver. i would offer to beta test a version but since i dont have any hands on tunning time i wouldnt be much good to u guys as far as helping goes. just let me know thanks
John
