Embedded Lockers, HUD, and the Ultimate TBI code
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Originally posted by RBob
The BLMs will bring the AFR in line according to the O2 window values. How much the BLM moves depends upon how far from 14.7:1 (the commanded in closed loop) the O2 window values are.
RBob.
RBob.
Hopefuly if you have used the WB to tune with the BLMs locked, there would be little to no adjustment required. I bring the issue up because I see a discrepancy between what the WB says is 14.7 v what is indicated by the NB. So you could be tuned fine with the WB, but then the ECM would be modifying that tune to match the NB input.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Guys,
I can tell you there's nobody more anxious to release this thing than RBob. On the other hand, he won't put something out that isn't complete and that won't be bulletproof. Let's just let him do his thing. He'll let you know soon enough.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hi, just wanted to let everyone know that I'm still here. Been busy working on some new analysis application software along with building EBL boards. Which is why I've been no-where to be found.
A different approach is being taken with regards to the PC/Laptop analysis application. Once this is usable the EBL system will be available.
An area that I can state as ready, is the ECM code, ECU, and calibration table documentation. Once I have a suitable analysis application program I will be offering the Embedded Lockers system. I'd like to offer it now, but that would not be fair to the end-user. It needs a usable data logging and an analysis program to go with it.
This post is a little short, but that just means I've been working on the data logging/analysis end of things.
RBob.
RBob.
Jim
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
so hows it coming bob? any luck with the bugs?
Car: check
Engine: check
Transmission: check
Originally posted by BronYrAur
Don't want to bother you too much, but does this mean that the HUD application will no longer be used? I take it something less system intensive is going to be integrated?
Jim
Jim
The reason I haven't been around much is that I have been working on an EBL app. This app is for analysis and support of the EBL system. Once I have the required functionality I will be releasing the EBL system.
RBob.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Guys,
I just happened to be playing back a datalog from the HUD/EBL combination I have. I gotta tell you, what Jon has created is a graphical ECM bench. Its pretty awesome when you think of it.
RBob, would we be able to playback a datalog through both the HUD display and the analysis software you're creating?
Dominic
Dominic
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by Dominic Sorresso
Guys,
Dominic
Guys,
Dominic
I was just reviewing some data as well, on of my ported 081s decided to crack and I had to swap to a set of stock port 187s just to get back on the road. I WAS rich in the mid-upper RPM range. Now I am not. 60 miles and the fuel table is already done, well atleast until I start on the timing. Fuel, timing, fuel, timing, fuel, timing, TCC, fuel, timing, etc.
FWIW, You'll should see the HUD in action on a 2.13 GHz XP machine.
My new laptop lacks a serial port but has like 6 USB ports. I picked up a serial-usb converter from Walmart for $10.00 that works great with the EBL setup.
It is an IOGEAR GUC232AWM. SK# Z752033BGV0522. It comes in a silver/green box approximately 5"x5".
It is able to keep up with the EBL for the duration of the datalog, unlike some other lesser more expensive units that I found ($40.00 Radioshack POC)
Car: check
Engine: check
Transmission: check
Dominic
Dominic
This is to be sure that the MPG calculation is accurate. The same technique is being carried throughout the application. I have some more work to do to it, but once it has the features to allow for tuning I'll be releasing the EBL system.
RBob.
P.S. to answer the question before it is asked, yes, this analysis program also has a graphical display.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Fast,
I am using the HUD on my 2.4Ghz MPC Laptop. Watching the flags turning on and off is great. Seeing when you're in DE or DFCO, PE etc. And watching the DC% and PW along side the Knock Counts is really handy when tuning for WOT. Everything is right there. I haven't used the AutoTune, sounds like you may have?
RBob,
Thanks for the update. Sounds awesome. The weather has been c*ap here and haven't been able to get out this week to test.
RBob,
Car: 1983 G20 Chevy
Transmission: 4L60
Fast,
RBob,
Fast,
RBob,
One of the best things I did for in-town MPG was install an amber light on the dash connected to the PE output, it really does help save gas, IF you make sure not to turn it on by using a light foot.
I make the same 140 mile trip almost every weekend. I typically set the cruise at 75 and just go. With the cruise set, 4 people with me, in lean cruise, running about 2,300 rpm with the A/C on I was able to get 19 mpg this last time.
I think that says something about this code, not only is it performance based, it is efficiency based as well. One of the ways to get more power is to be more efficient and this code does it well.
I am thinking it is time for dual TBIs. I have two ultimate TBI moded V8 tbis, and four 2.8 injectors laying around. I have a feeling that the air/fuel mixture will be better distributed. I am pulling a vacuum on the BB TBI with my 305, so there should be some performance benifit as well.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Fast,
Try using a modded CF manifold. With 2" TB's and 80psi Injectors that should be more than enough for your 305.
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
man, I'm anxiosly waiting for the release. I could finally tune for the VAFPR, not have to buy a shift light, hook up my taurus electric fan, not have to buy a window switch for the n2o, then I'll be all set for the twin turbos. hehe
Car: 91 rs
Engine: 355 LT1
I am just starting to get into tuning and it is a bit overwhelming. I was just wondering if the autotune feature will eliminate the need for learning DIY tuning or is it to be used more as an aid for tuning? Basically, could joe shmo install the EBL and turn the autotune feature on and after driving around for a while have a tune that is more or less dead on? Sorry if this has been covered before but this is a very long thread and I might have missed it.
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
This might work for a stock to mildy modified motor but I could not see it programming something like heads or cam for you. I'm sure someone that has actually used it will be able to give you a MUCH better answer but I'd say don't count on it doing all the work for you.
Car: 1983 G20 Chevy
Transmission: 4L60
I had to switch the heads on my 305, cracked one of the 081s, long story short, I ended up with a stock 187, big cam combo. I autotuned it to get it close, then tweaked it from there.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
I have been tuning using my ZT-2 WB. Basically, the BLMs and INTs are locked during this process and motor is running off what's there in te VE table. In the last several weeks, I have turned the BLMs and INTs back on so that the ECM is now doing some learning and modifying the VE table based on the O2 sensor input. Its pretty close. I would like to use the "Learn" in EBL/HUD to tweak the last few rough spots . I'd agree with Tier tho that for heads and cam package (like mine for instance) you'll need to get the tune reasonable.
Engine: 305 TBI
The autotune feature doesn't do timing either does it?? If that's the case he'd definitely need to learn how to tune himself, timing is very very important in getting the tune right or even close to right.
Car: 91 rs
Engine: 355 LT1
I am already in the process of learning tuning right now, actually I just burned my first chip last week. I was just wondering if the EBL would be a good place for a beginner to start, or is it going to take the same know how as before, just take a lot less time. You pretty much answered my question.
Engine: 355
Transmission: 4L60
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
If you've already gotten the tune to the point where your BLMs/AFR is where it ought to be, what else do you look for in doing the SA?
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by 89stroker
o man, i'm so excited for this EBL to come out. i'll finally get my 383 running right.
Engine: 305 TBI
Bron,
Bron,
Just saying, i wouldn't want to dive into tuning a motor wihtout knowing "how" to tune the motor and just letting EBL do what it should, if something went wrong he'd never know it, ya know what I mean?
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Bron,
I may not have phrased it correctly. I actually was curious about what process you use for tuning SA once you've tuned VE.
Engine: 305 TBI
ahh sorry I didn't catch that. To be honest I rough out a pretty basic spark curve then get the VE dialed in. Then I just kind of go off of idle quality and try some different spark advances around my idle and see where it smooths out the most and then smooth the curve around there. Then see what advance makes the most power and smooth the curve around that. I haven't done a ton of tuning on it yet though because i just recently got it running good again and now it's covered for the winter and I'm down in Champaign. I'm going to be doing all my tuning over the spring/summer. I definitely see if I have any knock though anywhere and try to get rid of that in the areas where it may have occurred (hard to tell with the slow baud rate) but I try not to rely on that much at all. It's been more of a SOTP "feel" thing, whatever gives best driveability in midrange, smoothest idle and best power in their respective cells.
Car: 89 K2500
Engine: 383 tbi
Transmission: built 700r4
Axle/Gears: 4.10 14 bolt
Originally posted by Fast355
Leaving Brian and the Holley behind will help tremendously.
Hi guys just keeping it fresh.how`s it coming bob?
Car: check
Engine: check
Transmission: check
I think you will like the What'sUp Display. It has a main graphical display that is similar to a virtual dash. Then 3 other screens: a trip computer, VE learn, and spark knock. The trip computer shows MPG (instant and average), fuel consumed (in gallons), and miles traveled. This display is in large block letters so that it may be read from a distance.
The VE Learn screen shows one of the three: original BIN VE %, learned VE%, or the corrections in %.
The spark knock screen shows one of the three: average knock, peak knock, or total knock.
The VE & Spark screens show this information in a table format. Such as seen in a BIN editor. The current MAP/RPM intersect is highlighted with a color block. The color of the block in the VE tables defines whether it is actively learning or not.
VE learn can be via WB input or BLM input. User selectable, along with which WB and input channel.
For a little of the technical side, the What's Up Display is a multi-threaded process. This allows all data accumulation to take place in the back ground. No data is lost even if a drop down menu (such as help or preferences) is selected, the data collection and display stills runs.
This means that a user can start the program, enable VE learn and data logging (has playback also), then switch to the MPG screen for driving. The data will be logged, the VE learn will take place, and the sceeen will be displaying the MPG.
The user can switch between any screen and the What'sUp Display will still be data logging, VE learning, and keeping track of the MPG. Even the spark knock screen will show the correct data as it is always collecting.
I have other functionality to add, and I'll do that once the EBL gets going. What's Up Display updates will be free and readily available to all EBL users.
RBob.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
D@MN.... you've alomst got me thinking I need to convert from my '730 AUJP based SUperRam to a TBI on my 383, and I never thought that would be possible!!! LOL
So, when you doing the TPI version? Hmmmmmm??????
I'm willing to go on record as your first TPI tester!
Car: 91 RS
LOL
I think the line forms to the rear........
LOL
I'm sure you're right about that one.....
Car: 1983 G20 Chevy
Transmission: 4L60
Me too. I am awaiting getting to tune the EBL on a basically stock 350 TBI. I am wanting to see what happens compared to a stock ECM with the same stuff. I bet it runs alot better on the EBL than the factory ECM.
Car: Suburban
Engine: 327
Transmission: TH400
Docs
Has any of the final documentation been released? It only makes sense that the WUD doc would be incomplete, but I was curious about the hardware mod instructions.
Car: check
Engine: check
Transmission: check
Re: Docs
I'm going to finish up some install info this week. For pic's I have a site that I should be able to put them on. Once I have some stuff there I'll let everyone know.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
Just thought that I would show some screenshots from the new crate 350, while I was breaking it in.
Note that this is with a near out of the box EBL calibration, on a new 350 that I was driving rather aggresively in town to seat the rings.
D@MN!!!!
That is some really neat looking stuff! Kudos to RBob and the team working on this effort! AmAzInG!!!!
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Guys,
I am hoping to get the car out this weekend and do tuning using the WB and Learn function. What's awesome is playing back a datalog and watching WUD run through the RPM/MAP plotting where to change the VE or where it is picking up Knock Counts.
And in O/L, it'll even make changes to tune WOT for the commanded AFR. RBob is a ***.
Engine: 305 TBI
Man, that's awesome stuff.
Dom, I'm going to show up at your doorstep this weekend so I can see it in action haha
Car: 91 RS
Rbob.......Great job.
Display looks clean, neat and to the point.
Car: 1983 G20 Chevy
Transmission: 4L60
Originally posted by DM91RS
Fast.......What do you mean by an "out of the box" cal.?
