minimum %TPS enable PE
Car: 88 T/A
I have my minimum %TPS to enable PE set at 55%, but it appears on my logs that I'm entering PE at about 43% TPS ( timing jumps up, blm's hit 128). My minimum LV8 to enter PE is set at 50. Why is this happening?
Car: 91 Red Sled
Re: minimum %TPS enable PE
Car: An Ol Buick
Engine: Vsick
LC4FD: 0x32 ;Minimum LV8 to Enable PE ;Val = LV8
;Minimum %TPS to Enable PE vs RPM
LC501:
Car: 88 T/A
Interestingly enough, the stock AKFN bin is set at 20 LV8 to enable PE. The thing that kind of confuses me, though, is that I'm far beyond 20, or even 130 before PE kicks in.
Car: 91 Red Sled
All of the $6E stock bins I've got (12 of them) all have 50 set as the min Lv8.
Is it possible that your ads file calibration for TPS is incorrect? Just because your log says 43% doesn't mean that the ECU is not reading as 50%.
Do like Grumpy said, try some other values, higher and lower. If you change 5% and the log shows 5% change, I would say your ALDL definition file is offset or scaled incorrectly
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
MikkoV
Sep 9, 2015 04:25 PM
