TunerProRT creating .ADS definition question
Old Sep 25, 2005 | 09:57 PM
yager's Avatar
Car: 1997 Jeep Wrangler
Engine: 2.2 L61
Transmission: R150/AX15/Toy T-case
Axle/Gears: 5.29
Im working on a definition for my $9A and ive looked at a few other .ADS files and have a few questions..
How exactly does the command sting function work when in 160 mode.
I see some that have a command called 'No Command 160' others that have none.
Should there be one as a dummy? Simply ignore it?
I see some have some strange values and i don't understand their perpose...
Whats the correct procedure on creating these ADS files properly?
Any other tips? tricks? Commets
I've searched across 4 differnt forums and most people seem to post here so I figured id ask here...
Thanks -mike
Old Sep 26, 2005 | 12:20 PM
yager's Avatar
Engine: 2.2 L61
Axle/Gears: 5.29
ok answered my own question....
When i took one of these 'older' files with the extra 160 command syntax and loaded them and then simply just saved it. It automatically removed this other 160 command syntax, my guess this was needed maybe before the 160 baud check box was used/in place...
Old Sep 28, 2005 | 11:58 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Correct. For 160 baud you don't need any specific command bytes, but you do need to have at least one command in the list (i've been meaning to fix that).
You did the right thing by templating another file. The only other critical part is that you have the response packet size set correctly.
Fronzizzle
Mar 18, 2019 08:29 PM
87iroctheo
Dec 4, 2016 11:47 AM
TEEZER TA
Aug 30, 2015 06:35 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
