Prom Error after "converting" aftermarket chip
Old Sep 26, 2005 | 08:43 PM
trailwing's Avatar
Engine: 355, Edelbrock heads, Compucam 2030
Transmission: NV4500
I have a question. After burning several chips on my own, I decided to try an aftermarket chip. I copied their 2732 and programmed it to the 29C256 chip that I'm using. The chip actually works pretty good and datalogging produced great BLM numbers right off the bat.
Unfortunately, WinALDL is indicating a "Prom Error" flag. No flashing lights and it runs just fine. Do I have a problem here? I tried another chip and produced the same results. I didn't have this problem when I originally reproduced the stock chip, but perhaps I dorked up an offset or something. Would it still run fine with a bad offset?
Old Sep 26, 2005 | 11:34 PM
trailwing's Avatar
I experimented with several programs (both old and new versions) attempting to isolate the problem. Finally, I renamed the PROM ID from the manufacturers P/N to the stock PROM number. Possible coincidence, but it seemed to work.
I was primarily concerned that something was wrong and would cause damage the computer or strand me. This is 30 seconds of your life that you won't get back.
Old Sep 28, 2005 | 03:03 PM
Ronny's Avatar
a few burns back that happened to me. car ran OK and no CE light. just prom error in win ALDL. maybe chip was some what defective or burn was incomplete. dont know.
Old Sep 28, 2005 | 03:53 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Probably didn't have the checksum calculated properly. But if it's working fine now you should be good to go. No worries.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
