High BLMs.
Old Sep 30, 2005 | 10:06 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
High BLMs.
Hey.
Engine specs;
Holley Stealth Ram,
Edelbrock performer RPM heads
Comp cams XE268.
Heres the deal. With timing at -2* the BLMS are around 130 idle in gear and 140 idle in park and the car seems to idle and drive fine.
When I put the timing to where it should be, 6-8*btdc the BLMS are around 140 in gear and 150+ out of gear. When the timing is at this, the car surges at idle and low load cruise.,
Any ideas? Could this be a vacuum leak or just a tuning issue?
Old Oct 1, 2005 | 03:37 PM
bubba353z's Avatar
Car: 07 Honda CR-V
Engine: Yes, there's one in there...
Transmission: One that shifts itself
Basically you are running too lean. Have you done any tuning with the new combo?
Old Oct 1, 2005 | 04:59 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
yeah id be very careful w/ blms that high im just a newb to tunning but u could easily be destroying pistons running that lean i would think since the target zone is 128.
Old Oct 1, 2005 | 09:56 PM
88TAJeff's Avatar
Car: 88 T/A
IMO the only way to fix that prob -which I had myself - is to start burning your own chips. You're way lean.
Old Oct 1, 2005 | 10:10 PM
I have the ability to tune my own chips, but just got the ALDL cable.
Running blms at 140 is likely causing my surging condition at idle and low load cruise when the timing is at 6*, correct?
Old Oct 1, 2005 | 10:27 PM
bubba353z's Avatar
Car: 07 Honda CR-V
It certainly isn't helping, although there could be other contributing factors.
Get the BLM's down first, and if that doesn't solve the problem start looking for other causes.
There are some good posts here on surging - do a search and you'll find them.
Old Oct 1, 2005 | 11:30 PM
88TAJeff's Avatar
Car: 88 T/A
As for the surging, my car had that for 4 years, bucking at light load, low rpm. I checked every possible thing you can imagine. Turned out to be a large transition in the stock timing table- smoothed it out a bit and it solved it immediately.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
